Question about Coffee Makers & Espresso Machines
The wather is not coming from cup
No wather from expresso unit
  • 1,511 Answers
No wather? Sounds like you need to clean the ports on the heating unit. The manual should have the procedure for cleaning the machine.
Posted on Mar 25, 2014
Orange light on delonghi nespresso
Sorry chaps, all these suggestions are wrong. The orange light on the small cappuccino button means the unit needs to be descaled. See Nespresso support to download the user guide and you'll see this explained there
Feb 20, 2013 | Coffee Makers & Espresso Machines
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
No water comes out when making coffee--it does come out when making expresso. what do i do?
Hi
Try and reporgram that button. Hold it down through the whole process and when you get the amount of coffee in your cup that you want, release it.
Jun 16, 2010 | Solis Palazzo Espresso Machine
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
My palazzo only works when i press the button for expresso?it doesnt work when i push the button for the bigger cup ?
HI
If it works for espresso, but it doesn't work for the large cup, try holding the large cup button down and keep it down. Let it go through the grind, the clicking, and if it starts to dispense coffee , still don't release it until you have the desired amount in your cup. Then release it.
If one of the coffee buttons is held down for 3 seconds or more and then released, the water program goes back to zero. No water. You have to reprogram the button like we did above.
Nov 08, 2009 | Solis Palazzo Espresso Machine
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Cafe Roma Expresso/Cappucino machine
My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
HELP FROM EXPRESSO NEWBE
What kind of machine do you have?
Sep 15, 2007 | Saeco 30511 Espresso Machine
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
