Question about Vizio L32 32 in. LCD HDTV
The digital programming here and I can't get any channels clearly
The day digital programming came in I got several channels clearly. Since that day, June 12, I can't get any channels clearly. If I start to receive one it becomes broken up into blocks and I loose sound. I need help.
    President:
  • 1,077 Answers
Well, there is nothing wrong with the TV itself. The signal is too weak to get enough digital information to complete picture and sound.
You may need a better antenna for reception.
There are some long range digital antennas and antennas that will receive signals in all directions.
It's the best way I know of to solve the problem.
Posted on Jun 15, 2009
  • 3 Answers
Rescan the converter box and or tv.
Posted on Jul 05, 2009
Is there a switch or something I need to do to get my tvs to get analog channels clear when I am hooked to cable?
See if the tuner on the TV has a provision to add both analog AND digital channels as a choice. If so, then select that and then do a new channel search. Ask if the cable company uses standard or irc channel spacing and set your tuner on the TV to match.
Oct 17, 2016 | Audio Players & Recorders
Technogym manual
  • Several programs available.
    • Cartoons'
      • Bugs Bunny on channel 6
      • Road Runner is on Channel 12
    • Soap Operas
      • A day in the life of Rodney on Channel 3
      • One Life to live on Channel 9
Aug 14, 2014 | Body Solid Best Fitness Spin Bike BFSB10
What is a 'subchannel'?
as in 4.1 or 5.2? its a digital over the air channel that is owned by the same station as (i.e channel 4) but may offer different content. such as movies. hd version of the channel etc.
Mar 22, 2011 | Insignia IS-LCDTV32 32 in. Television
How do I delete one of the set programs on my utiltech 7-day digital timer? The directions say press the mode key, and keeping it held down, press the program key, it doesn't work. Any suggestions?
Clearing event on Utilitec 7-day timer:
Tiny print on instructions say: press PROG button several times to locate setting you want to clear > Press and hold MODE button > press PROG button to clear setting > to finish, press CLOCK button and display will show time of day.
In case of operational failure:
Tiny print on instructions say: press RESET button to clear all settings >> and then reprogram
Sep 12, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
Apr 21, 2009 | Panasonic DMRES15 DVD Recorder
When changing channels sporatic static,
Please feed again cable channels in TV by selecting Auto Search / channel preset in TV Menu.
This will update channel data stored in TV memory.
Mar 18, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The lower half of the screen is a black box on one channel
Check your closed-captioning settings. You probably have it set for "text". Make sure you turn captioning off and the problem should clear up.
Feb 12, 2009 | Recoton Advent Advent Q2035A 20" TV
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
Programming favorite channel scan
After you hold down the P button and the leds blink you put in 996 then the led's blink again. Once this happens all you do is put in the channel you want as a favorite, and then hit P For codes less that 4 or 5 digits you hit the enter key. ANd it isn't clear how many digits to put in for a channel with 2 digits but it looks like if you put in anything under 99 you will want to put in 099 098 097 etc etc... Hope that helps some
Aug 27, 2007 | Radio Shack (15-2147) Remote Control
Vizio L32 32 in. LCD HDTV Logo
229 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
