Question about Saniflo Home
Have a saniflo compact on which the button now takes 2 or 3 pushes to activate flush, is button a serviceable part?
Saniflo compact has single flush button about 12 years old
  • 659 Answers
SOURCE: saniflo ejector experiencing shaking when flushed
I have included the installation instructions. It also includes an expanded veiw of the toilet. The troubleshooting area can give you ideas. From what I read, it is possible that something has feel into the grill. Hopefully this helps.
http://www.saniflo.com/pdf/install/PLUS_US.pdf
Posted on Apr 18, 2009
  • 82 Answers
SOURCE: my saniflo makes a loud noise with flush
It could be one of a number of things:
1. Full of gunk and will get quieter if it gets cleaned out - two ways of doing this ..
a) Try the saniflo descaler / cleaner product http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
b) If you are comfortable with it, to clean:
1. Turn off the electricity to the unit (should be on a fused spur)
2. Disconnect the pipes (inlet and discharge) - you may get a bit of surplus water coming out so have some sponges and a bucket ready.
3. Disconnect the wiring and take the unit out
4. I clean my Saniflo's outside with warm bleach water ..
- Wear rubber gloves to keep germs out of any cuts you may have / get on your hands
- Put the elextrical cable in a taped up plastic food bag or similar to keep dry
- undo the 'star screws'
- Flip up the plastic retaining tabs with a flat blade screwdriver and gently ease the lid up.
- I put bleach and warm water in, leave it for a while (30 mins) and then swish it around and empty out into an outside drain etc
- If you want to use an old toothbrush to get into the areas by the float switch and under the motor it does help. I also used a hosepipe in the past which did the trick.
- Also pay attention to the inlet port and the actual pipes under your sink for gunk
put it back together, aligning the seal and plastic clips should just pop on (may need a firm push). Do up star screws and you are ready to reconnect the pipes and electrics.
I use some tissue paper to check for any leaks around the pipes just to be sure!
2. The bearings in the motor for the pump may be going (i.e. have play in them) and be causing noise. This normally means a replacement unit
3. Something is in there that should not be! ... i.e. toy soldiers etc etc (see cleaning)
Hope this helps
Posted on Jan 24, 2010
Obertelli
  • 3006 Answers
SOURCE: Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
Posted on May 29, 2010
  • 115 Answers
SOURCE: we have a saniflo compact the toilet will flush
This could be a problem with the capacitor that has gone bad or something stuck on the blade or impeller and is not allowing the waste to be pumped out. Typically when the capacitor has seized up or there is a clog on the drain pipe, blade or impeller; the unit will just hum and not pump the waste out and eventually back up on the toilet and overflow.
Posted on Oct 11, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a problem with a newly fitted saniflo that
You are right. With all of the energy saving plans going they think that the pump should not run every flush. That is why it is taking 3 flushes to turn on the pump.
Posted on Oct 26, 2010
Can the flush mechanism be moved to an external site
Well now, that depends on your ingenuity.
If you can exactly duplicate the action of the flush handle, of course you can move it anywhere you please.
I am at a railroad museum, and railroads could move track switch lever mechanisms several hundred feet away from the switch, it just takes imagination and precision.
Saniflo will not be able to help you, but an inventor might be delighted to do so.
God bless your efforts.
Dec 15, 2015 | Saniflo Home
Saniflo compact part flushes when being used
Of course you should , the MAKER should make it right
May 22, 2017 | Home
Hi I have a saniflo compact which won't flush on the first press of the button - it takes several goes. Can anybody advice.?
Replace the the button switch it has or is going bad. You can try taking it out and cleaning the contacts but this hardy ever works.
Mar 20, 2011 | Saniflo Home
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
I have a toilet with a push button flush mechanism (allowing half or full flush). The toilet has a macerator behind it. If you flush the toilet and the macerator jams, the push button stays stuck in and...
This seems like a problem with your cistern and not your macerator - I have a similar set up and if your push button is stuck you need to check the mechanism in the cistern - also you should have an overflow that drains into your loo within the cistern so you should check this for blockages as well.
Oct 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
We have a saniflo compact the toilet will flush 3 out of 5 times and the motor sounds fine but the other times when flushed it will sound like it is trying to flush and then just turns off at the end of...
Sep 30, 2010 | Saniflo & Saniplus& Macerator Pump
I fitted a saniflo plus about 3 months ago engineer been out 5 times even changed unit last engineer said it was toilet paper stuck in tiny hole at bottom of motor he said it was due to not flushing...
This could be a problem with the capacitor which drives the blade and impeller. If it goes bad it will pump water only but when solids are flushed, it will jam the blade and cause it not to spin. You may have to replace the capacitor/condenser.
Nov 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Fills but wont flush
Check the electric power to the unit first as the compact is all controlled via a printed circuit board
Jul 25, 2009 | Elite Saniflo SaniCompact- SaniCompact One...
Home Logo
29 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
