Question about Water Tech Blue Diamond Pro Robotic Pool Cleaner
It immediately shuts off after I press the "on " button!!
That's it
    New Friend:
    Problem Solver:
  • 6 Answers
The power converter is bad and needs to be replaced. Check and see what warranty the manufacture might supply. ( I deal with this all summer long at our store)
Posted on Apr 04, 2014
Starting iMac OS 10.6.8
Hi Jan,
If you see a spinning grey earth globe, then it's an easy fix.
Starting from a shut down mac, press the start up button then immediately press and hold the Alt button until you see your startup disk appear, release the Alt button, ... select your startup disk and then hit return. The mac should boot up normally.
then immediately go into the System preferences and choose the StartUp Disk icon and make sure you select your harddrive as the start up disk. somehow, network disk was selected and it is timing out looking for it...
Mar 02, 2013 | Apple iMac Computers & Internet
My HP laptop restarts when I try to shut it down
Try checking if your power button is defective. Check if it's stuck.
Dec 20, 2012 | Computers & Internet
Mac g5 wont start led light blinks once every 7 sec
Hold down the power button until the computer shuts off. The press the button to restart and see what happens. There are several different ways to startup. immediately upon hearing the boot tone, press and hold the shift key to boot in safemode. If this fails as well, then you will need to boot with the install CD. This is done by immediately pressing holding the C key upon powerup
Jun 27, 2012 | Apple Power Mac G5 Desktop
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
Due to c00002la fatal system error problem I am unable to shut down.
Shut down your PC by pressing restart button then immediately shutdown button, Next time when you start your PC, press F8 during startup before the window logo comes up, and choose "last configuration that worked". If the last known good configuration does not work you may have to reinstall the operating system. Visit this link to resolve this error.
Thanks..!!
Nov 26, 2010 | Computers & Internet
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
Shutdown sometimes fails - Lens retracts then immediately extends again
I am having the same problem with my camera. I have to take the batteries out to get it to shut down. I also cannot view my photos on the camera, when I try to turn it to view, it goes to shoot mode.
Aug 01, 2008 | Canon PowerShot S3 IS Digital Camera
Philips TV model 20PT9007D/17B immediately shuts off after powering on. Pressing channel change keeps the set on but then shuts off when stop pressing channel change.
Sounds like you may have had some fluid go from the screen to the buttons on the main board...like Windex or something, and is causing a short in the buttons. The only way to repair it is to have the main board removed and cleaned or have those buttons replaced.
Jul 22, 2008 | Televison & Video
Water Tech Blue Diamond Pro Robotic Pool Cleaner Logo
233 people viewed this question
Top Water Tech Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Water Tech Pool and Spa Expert? Answer questions, earn points and help others
