There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom,
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the
appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
