Question about Givi Windscreen Kawasaki ZRX1100 97-00 and ZRX1200R 01-04
Loud crach noise when starting bike
Bike seemed like it had flat battery when trying to start but tryed again after short pause bike fired up after a loud machanical crack and also seemed like it wasnt running on all 4 cylinder for a short while but then run sweet
Yamaha 550 vison won't start only making a clicking noise I've had the battery changed full charged and when I hit start it gos dim and clicks once
Sounds like the starter is stuck. Sit on the bike put bike into gear without ignition on a lightly rock bike fowards and backwards you migh hear a loud click or clunk then try starting as normal
Jun 08, 2015 | Yamaha Motorcycles
Loud speaker static when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to get it to stop. Any ideas?
I GUESS that the speakers are driven by an after market amplifier. An amplifier needs to be connected to a power source that is only on when the radio is on, through a relay.
So I GUESS that:
  1. The wiring is incorrect. Or
  2. If is has a relay, the relay is stuck.
Feb 01, 2015 | Cars & Trucks
I just purchased the 2004 road star. The first thing i noticed is the battery was dead. I checked it.. lots of Voltage ..no amperage. I purchesed a new one. As soon as i installed this, I tried to start...
There could be a number of problems here ,It may be your regulator is playing up and draining your battery ,or you may have an earthing fault .best advice is to get an electician to check out the wiring system .It cheaper that bying diffrent components in the hope it will solve the problem.
Mar 12, 2010 | 2004 Yamaha Road Star Silverado
Bike will not start
flat battery,,,,try charging it up then try starting the bike again dont charge the battery using more that 1 amp power
Mar 09, 2010 | 1992 BMW K 1100 LT
Bike ran great engine was at running temperature. Tried to restart after a short pause. Engine seemed to backfire when I hit the start switch. When I finally got it running would not stay running and had...
If you have the on off and reserve petcock or fuel valve then its not the old vacuum type. If battery good time to check basics so you see fuel squrting into the engine through the carb when throttle turned ? do you actually have spark at the plugs ?
Jul 22, 2009 | 2001 Harley Davidson FXDXT Dyna Super...
Burgman 250 will not start
Ck fuses and wire connections first. If no problem seen, get bike running and disconnect the ground cable @ battery. If bike dies the problem generally is in the stator or regulator assembly not keeping battery charged. Bike will run untill the battery is too low to keep the ignition system energized and the bike will die. If it continues running w/the ground disconnected, the battery could have a dead cell which will drain the battery in a very short time whether it is running or not.
May 03, 2009 | Suzuki Burgman 250 Motorcycles
2002 starter problem
your battery has a bad connection or is dead. the clicking noise is the starter relay working.
Mar 16, 2009 | 2002 Honda VT 1100 C Shadow Spirit
My 650 v-star wont start cylinode is clicking
Your battery is too low. Take out the battery and have it tested.
Mar 06, 2009 | 2004 Yamaha V Star Classic
V star 1100 05' starting problem
Hi Bullsport,
This problem occurs on too much starter cranking i.e. the engine doesnt respond or fire up at a go.
Try to check the bike's spark plugs.
Probabley it needs a good tune up ( the bike).
Good luck.
Knight( Yamaha Seca XJ750 A 1981)
Feb 12, 2009 | 2006 Yamaha V Star 1100 Silverado
Wont start
got a charger and it ended up being a dead battery.---- If that's the original battery, it's probably toast. You'll probably do well to search for a replacement at this point. Bike batteries are generally considered short-lived. The longest lasting battery I ever had in a bike went 9 years*. But that's so far away from a normal lifespan it's almost ridiculous. I suppose the average is more like 4-6 years but the modern, Maintenance-Free types seem the best.
Nov 10, 2008 | 1985 Yamaha FZ 750 FT (U.S.)
Givi Windscreen Kawasaki ZRX1100 97-00 and ZRX1200R 01-04 Logo
70 people viewed this question
Top Givi Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Givi Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
