Question about John Deere Garden
How do I fix a solonoid for 575 uniloader?
Replace new fuel solenoid won't shut off.
  • John Deere Master
  • 2,478 Answers
I had the same. I installed a fuel shut-off in fuel line. To make sure it turns off.
Posted on Mar 25, 2014
Carb solonoid wire burned , runs intermitent rpm plus backfires on cutoff of ignition
if that wire burned you may have burned other wires
check them all
cut off the end of solenoid so no fuel obstruction, or replace and hook up correctly
Jun 24, 2016 | Garden
Where is the fuel shut off solonoid located on the cub cadet mower
fuel shut off solenoid valve is on bottom of carb bowl
Sep 06, 2014 | Cub Cadet Garden
Remote car starter
check the fuel shut off solonoid on the pump as these can stick and jam up so when the ignition is switched off the solonoid is still open alowing fuel to still be pumped into the fuel pump
Dec 31, 2013 | Ford Cars & Trucks
Expert van cutting out
P0215 Fuel Shut Off Solenoid -Circuit Malfunction
Sounds like this is a diesel version and you havent posted what year it is as if its a newer common rail then its a dealer only or a better still a bosch diesel injection specialist ,although a modern diesel has electronic controlled injectors so this could be a pre common rail version and the solonoid is on the injector pump but you will still have to remove the injector pump to get the shroud off to get to this solonoid and they cost around 90 euros
Feb 15, 2012 | Peugeot Cars & Trucks
Which solonoid do I fix on a 2000 Impala Evap System (code P0441) The vent solonoid or purge solonoid?
you see code po441 the purge solenoid could be faulty or disconnected. if you have problem with evap switch to vent solenoid you would smell gas fumes in vechicle.check make sure gas cap on tight not leaking because it will set off code po441.
Feb 07, 2012 | 2000 Chevrolet Impala
The fuel door in my car would not open had to pop it open how do i fix it so the button will work again
usually they are opened via cable. you'll have to trace the cable and replace it, if it's broke. Sometimes you just need to lubricate the lever where you activate the door.
kdog
Dec 29, 2010 | 1995 Ford Thunderbird
Big red honda 300cc 4 wheeler. Starter solonoid just clicks. Battery fully charged. solonoid has 2 wires from battery and a long double wire sealed into the solonoid. Question: How do you replace the...
if you can pull the rubber cover off the solenoid you will see two nuts that are the cable terminals, short across these with a screwdriver or similar(may make a spark) if this causes the starter to turn you probably need a solenoid. You could also try a multi meter or test light on the terminal to the starter, it should have power when you press the start button, if not , new solenoid. to change it disconnect the battery , undo the two cable nuts, and follow the other wire back to its connecter
Apr 25, 2010 | Honda XR 400 Motard Motorcycles
My dodge ram truck will not turn off, it continues to run. A 1989 truck dodge ram 1989.
if its diesel there is a fuel shut off solonoid that goes bad u can use ur fingers to lift the arm and the engine will die. the solonoid is located on the drivers side toward the rear of the engine. the arm points strait down. pull it up to shut the fuel up (caution sometimes the arm will spring up snappng ur fingers keep fingers underneath the solonoid arm
Mar 21, 2010 | Dodge Ram 50 Cars & Trucks
Idleling of 1984 F250 Ford PU
mcdevito75, That carb, solonoid most likely works with both, electricity and vacum, That blue wire should hook up to that solonoid, look at the plug ans solonoid and see if there"s a point for the wire. If it has broken off yo"ll have to replace the solonoid. Also have the choke system on your truck checked out, if the choke is not operateing as it should this too can cause your problem. Have your local repair shop take a look.
Dec 04, 2008 | 1984 Ford F 250
1991 eagle talon starting problem
its probably your fuel pressure solenoid. it is probably leaking vacuum to the FPR causing your fuel pressure to be to low. try disconnecting the vacuum hose coming off the fuel pressure regulator.
put your finger over the end of the hose and have someone try and start the car. (if your alone just plug up the hose)
if the car will start easily now, replace the solenoid and the problem should be fixed
Jun 08, 2008 | 1991 Eagle Talon
Garden Logo
27 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
