Question about Vacuums
Miele repair manual
On the S7280 Jazz Vacuum Cleaner, it will not release the body from the vacuum cleaner. I need to replace the foot pedal to recline vacuum. Where would I order the parts or talk with someone that might be able to tell me how to connect it or tear it apart?
reddevil6
  • 1673 Answers
SOURCE: miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Posted on Mar 06, 2008
reddevil6
  • 1673 Answers
SOURCE: VACUUM REPAIR
There are 2 tabs that stick out on the release, they fit in slots, so from the top look down and you can see them, using a flatblade screwdriver that will fit in there, push the side in to release it, which isn't easy, but it can be done. When you get the old one out, then the new one, push down on it until it locks into place.
SOURCE: Need the manual for this vacuum cleaner
Try this link also
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action
Posted on Jun 14, 2008
SOURCE: Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Posted on Jul 06, 2008
  • 12104 Answers
SOURCE: Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Posted on Mar 24, 2010
I am looking for a parts diagram for a Miele Upright S7280 (Salsa) vacuum
See if there is a manufactures web site and inquire if diagram is available or just Google for info with proper make and model.
Fist just search for vacuum diagrams then refine search for your vacuum but this not always easy can be confusing so might have to take it to vacuum repair business or if you have not dissembled it yet just make notes when you do. Its not as hard as it seems I have done it many times.
Oct 24, 2012 | Miele S7280 Bagged Upright Vacuum
Replacement Motor for a Miele S143 Vacuum Cleaner
Your vacuum should still be under warranty. If they dealer does not fix it for free call Miele directly.
Jun 05, 2010 | Miele S143 Bagged Upright Vacuum
Eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Eureka Smart 4870DT Bagged Upright Vacuum
PLASTIC HANDLE RELEASE BROKEN. WHERE DO I FIND A REPLACEMENT?
Greetings from GoVacuum.com,
We are a vacuum cleaner parts store, http://www.govacuum.com, and we carry parts for over 40 different brands of vacuum cleaners.
We almost certainly carry the handle release pedal for your vacuum cleaner. If you'd like to leave your vacuum cleaners brand, and model number (can be located on the back or the bottom of the vacuum cleaner on a sticker that will also contain the serial number), I would be more then happy to help you not only find the part you need, but also explain to you how to install the part.
Please feel free to click on "Clarification Request" here on Fixya, or send me an email to chris.jones@govacuum.com.
I look forward to helping you find the correct part for your vacuum cleaner, Please vote this repair as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of this repair.
Thank you so much,
Chris Jones
GoVacuum.com
Mar 19, 2010 | Vacuums
What kind of upright or steam Vac should I buy which can make my carpet clean and SOFT?
I recommend looking at the miele S7280 for an upright vacuum cleaner and the royal RY7910 carpet extractor.
Jan 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I need to remove the handle from the S7000 series vacuum cleaner to send it back to Miele as it doesn't work - how do I do that?
First, remove the upholstery cleaning attachment from the back of the vacuum. Next, move the cord to the side. In the recessed slot where the upholstery brush fits, you will see a small hole. Push a small, regular screwdriver in to the hole. At the same time, pull up on the Miele handle to disengage and to remove the handle from the body of the vacuum cleaner.
I did this by placing the vacuum on the floor with the handle down and pressing the screw driver against the floor with the blade of the screwdriver going into the hole. I held the vacuum with my feet and pulled firmly on the handle.
Sep 17, 2009 | Miele Vacuums
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
Vacuums Logo
217 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
