Vertical tearing, unABLE to conver.
Distortion is bd, horozontal and or vertical. suspect bad connection on horz and vertical boards, sometimes it is ok I would like to get a service manual and schematics
  • 8,617 Answers
You can get the service manuals for most TVs at the following link, they email them.
http://servicemanuals.vstore.ca/
Posted on Jun 15, 2009
When it is turned on half of the screen has vertical and then horz lines for approx. 10 minutes...then when it seems to be warmed up..the full screen is ok....no lines....as long as it is on its ok
You have to check the connection from the TCON Board to LCD panel. Sometimes Bad contact can cause such problem.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 19, 2016 | LG 42LC2D 42 in. LCD HDTV
Toshiba 52xf550u has distorted vertical lines right side of screen problem only 2 years old
All TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 11, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Hi, Two sets of lines have appeared on the screen
are these lines vetical or horz if they are vertical your panel has failed and will need to be replaced big bucks if they are horz , then it could just be the T-con board and you will need a tech to confirm this I have seen this problem cause by a poorly seated connection
Dec 07, 2009 | Televison & Video
I have a good picture then it goes horz. with static and then a good picture and then a horz. lines and static about every sec.
The horizontal line indicates failure of vertical section, checkout the output capacitor of vertical-section connecting to the yoke (vertical) for any loose contact, dry solder, capacitor wear-out.
Need to check the register and filter capacitor that powers the vertical-section.
Sep 28, 2009 | Sanyo DS25390 TV
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
TEAC CT-M685
This is a vertical-deflection problem. Try to adjust the vertical (height and linearity and hold) controls, which should be screwdriver potentiometer controls on the back of the set.
If this does not work, a defective component in the vertical-deflection circuit will need to be repaired.
I hope this helped you. :)
Mar 30, 2008 | Televison & Video
Jitter and tearing on bright pictures
1. VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Jan 21, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Kp51ws510
Did the set have convergence problems before picture left? If so then you can unplug the conver. Bd and see if set comes up then this will tell you where the problems lies. Or you can check IC902, Q800-810 D655
Dec 05, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony TV not working
This is not an easy fix for most people! I suspect the ps is blown, R607, Q601,Q602 (use all org Sony parts, lots of factory 2nds around). This stuff blows to protect the fuse!!!!! Very rarely the input bridge rectifier or filter cap short.
Check R622, if open or discolored also replace VDR601(doesn't go bad very often). Check Horz output Q502. Inspect whole board for any bad connections, all parts with heat sinks(regulator ICs). Horz driver transformer, 0.47uf to horz driver tr. There could be other parts bad (flyback??). Make sure no supplies are shorted, check audio output supply, vert output supply, etc. Easily $150 repair at a shop. Good luck!
Oct 27, 2007 | Sony KV-32S36 32" TV
Tv problem
generally buttons are located at front only. but if it is not there then it will be inside in the shape of small variable res. called preset. vertical hold button will be near vert.section &horz hold near h/ section.
Sep 30, 2007 | JVC AV-27850 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
