Question about MPC Computers ClientPro 414 All-In-One PC Desktop
Cant get sound on in my mpc client pro all in one
  • Deependra Shekhar May 11, 2010
    Need to check the sound card is installed properly under the device manager.
  • 177 Answers
Rusabus- I have the exact same problem, and I have the 30pin wire harness out, but there are no pins labeled. Is there any way to tell which ones are 7&8, and do I need to leave the wire in there? Would I be better off going with option 3? I have quite a bit of time
Posted on Jun 22, 2010
  • rusabus Oct 17, 2010
    Hi Donovanm,
    Sorry for not replying sooner. As I noted in my original reply, only pins 1, 2, 29, and 30 are labeled. What I did not mention was that they are only labeled on the motherboard. The cable itself is not labeled at all. To find pins 7 and 8, you will have to count from pin 1.
    --Russel
    Scholar:
  • 44 Answers
You either have a broken volume control knob or incorrect/missing drivers. You can download the drivers for this product from a company called Mecer:
http://downloadcenter.mustek.co.za/list.php?dir=Repository%2FMultimedia+PC%2FL19IA%2FXP%2F
Does your volume control knob spin more than 360 degrees? It should not, and if it does, then it's broken. Here are three solutions you can try for fixing it:
#1: This is probably the easiest one to accomplish. Remove the cabledooron the back of the system (it is the one at the bottom on the back --held in by one screw). Under this door there are anywhere from 5-6cables plugged into the motherboard. One of these is a connector with30 pins arranged in two rows of 15. The cable plugged into thisconnector probably has pink wires. Short pins 7-8 on this connector(they should be across from each other, but only pins 1, 2, 29, and 30are labeled). To short the pins, insert a thin wire into the back sideof the connector so that it makes contact with the exposed pins. Youcould also use a resistor to do the trick - 10KOhms will give you novolumewhile 0Ohms will give you full volume. Something like 2.5K could giveyou a nice middle ground.
#2:Replace the volume knob. The part number for the knob isXV0107GPV2NB10K-3824. Good luck finding someone who will sell you oneof these.
#3: Disassemble the LCD panel (it's not that hard ifyou have a #1 phillips screw driver) and short the volume control knobpins 2-3. This will disable the volume control completely, but it willbe stuck on maximum volume. This would be best done by soldering a wirebetween those two pins.
Options 1 and 3 will disable the hardware volume control, but the software volume control in Windows will still work fine.
Posted on Jul 01, 2009
  • rusabus Jul 01, 2009
    By the way, the above is only applicable on a ClientPro 414 all-in-one. The ClientPro All-in-one is a different product. It has a similar volume control knob (I don't know if it is the same, though), but uses different drivers. You can download drivers for it at:
    http://www.uniwill.com/UserDownload/L373...
  • 3 Answers
Do you see a speaker on your desktop on the lower right hand side? If you do, then click it and look to see if you have anything that is muted. If everything is fine then go to Settings and control panel and look in mutimedia. In audio, make sure your sound card is appropriately set. If you dont see a speaker or you dont see your sound card in multimedia, then you need to reinstall the drivers for your sound card. If everything checks out fine and it says your sound card is working properly...then check the speaker connection in back of you computer. Good luck.
Posted on Jun 16, 2009
3 Suggested Answers
SOURCE: Hardware support for MPC Client Pro All in one
tangent.com has purchased the right to the clientpro line.
Call Mark Gordon 1-800-342-9388 x1772
Posted on Apr 08, 2009
dkammeyer79
  • 92 Answers
SOURCE: drivers de mpc client pro 414 todo en uno 1
http://www.mpcdrivers.com/apps/filelist3194.html
Posted on Mar 01, 2011
Need wiring diagram for client pro 365
What was your original MOBO? It should help you identify the connections to your chassis/front panel.
Typically you will have USB, audio, ground, power supply and switching/reset lines.
Often the connectors are not compatible and you need to improvise.
A manual appears to be here for Intel 915GRV uATX Motherboard (ClientPro 365) (MBD001246-00):
http://www.mpcdrivers.com/apps/compdeteb4e.html
Use at your own risk. MPC died some years back and this is the official MPC/Gateway support site per Wikipedia http://en.wikipedia.org/wiki/MPC_Corporation
Oct 15, 2012 | MPC Computers ClientPro 365 PC Desktop
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
How to remove left cover client pro 365 tower
Usually, computer cases will have two screws per panel in the rear of the case. After you unscrew them slide the panel backwards, then lift.
Nov 18, 2009 | MPC Computers ClientPro 365 PC Desktop
Driver need to reinstall on this system
All drivers for MPC Client pro pc are located on Intel's web site. Once I located the model of the motherboard, all drivers were listed. All is well now.
Thank
May 01, 2009 | Office Equipment & Supplies
I have a MPC Client pro Model N373N1, I need an A/c adapter 20V 8
Go here they have or can get.http://www.5kcompany.com/Hardware/computers.htm.RICHARDM69
Dec 08, 2008 | MPC Computers ClientPro 414 All-In-One PC...
MPC Computers ClientPro 414 All-In-One PC Desktop Logo
307 people viewed this question
Top MPC Computers Computers & Internet Experts
Paul Bade
Muggs01
Muggs01
Mark Gough
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
