Question about HP Color Laserjet Cm1312 Mfp
Error 79 Turn off and then on appears. Followed the procedure but problem insists. Downloaded new firmware and run it but no results. Machine was not able to get to steady state.
  • Panagiotis Blanos
    Panagiotis Blanos Mar 25, 2014
    just realized that when the printer is not connected to the pc via usb there is no error and the printer goes to ready state. But when i connect the usb cable again to the pc 79 error appears. how am I supposed to upgrade the firmware?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • HP Expert
  • 146 Answers
2 Suggested Answers
SOURCE: Hewlett Packard Laserjet 2605dn Printer: Error 79 after firmware update
HP has now admitted their firmware update causes an irreversible corruption in the formatter board. It is hard to get them to do this, but I understand they will repair at no cost if they can determine that you did install this update.
Posted on Aug 17, 2012
Error code on B754e c-d385
You may have to check your Machine and Type settings during firmware loading. Since you have replaced the MFPB it may have mismatch of machine type setup. If MFPB was new then ensure it has Machine 2 and Type 0. Same applies to used MFPB. Reset firmware should be used, so machine can be set up properly to the relevant firmware loading.
Sep 30, 2016 | Konica Minolta bizhub Office Equipment &...
HP 400 stuck initializing
79 is an firmware error. Try to update the firmware. You can find the file on HP website, on the Drivers and Support section. There must be also the procedure to execute the update.
May 29, 2014 | HP LaserJet Office Equipment & Supplies
How to fix error 79 on a hp laserjet pro 400
Try to update your firmware if it is possible. 79 it's a firmware related error. You will find the update file and the procedure on HP webpage at "Drivers and Support" section. If the update won't solve the problem, verify if the formatter board is correctly plugged. Eventually pull it out and push it back firmly.
May 19, 2014 | HP Laserjet Pro 400 Mfp M425dn...
Jun 20, 2012 | HP LaserJet 2605dn Printer
I have a designjet 800ps 42" and send me the 79:04 error code, after this happen i change the belt and all the printheads, but it still send me the same error, it said Error Code:79:04 ...
Who told you to change the belt? 79:04 is a Firmware error.
Switch the Printer Off and wait a few minutes. Switch the Printer On again and check if the Error Code has disappeared. If the Error Code reappears, check for a new Firmware release. If the new Firmware release does not solve the problem, or if new Firmware release was not available, then contact the HP Response Center supplying the following information: - Model and Serial Number of the Printer. - Firmware release of the Printer
- The complete Error Code information, including the linefeed where the error occurred
Aug 19, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
System error e225
Hello 3G,
To resolve the issue Error e225,
Turn the main power switch off and then back on-ICMF 4000 series/D400 Series
or
Update the firmware :
There is a risk that the MF4150 will not operate if power interruption occurs
during the firmware update. Please make sure MF4150 is connected to
reliable AC power source.
1. Save the downloaded file "MF4150_FirmwareUpdateTool_V0xx.exe on local drive. (i.e. desktop)
Computer Requirements for update
- Microsoft Windows 2000 or XP (32bit)
- Equipped with a USB port (either 1.1 or 2.0)
- Free disk space: 100 MB or more
2. Make sure that Processing/Data indicator (Green LED) on the MF4150's operation panel is turned off.
If the light is lit or blinking, wait until all the jobs are finished (i.e., COPY, PRINT, and SCAN), and that the Processing/Data indicator is turned off.
3. Make sure that Error indicator (Red LED) on the operation panel is turned off. If Processing/Data indicator (Green LED) is lit and Error indicator (Red LED) is blinking at the same time, jobs are held in the printer memory due to an error, possible cause is out of toner or paper has run out, or toner cartridge is not installed. Check the LCD for and error message and refer to the documentation that came with the printer to resolve the error.
4. Disconnect Fax line cable from the MF4150 to prevent Fax reception interruption during firmware update.
5. Make sure the USB cable is directly connected to the MF4150 and your computer.
  • Do NOT use a USB hub to connect the cable, as it may lead to a connection error.
  • Make sure the machine is not in the Sleep mode (i.e., [Energy Saver] key on the operation panel is leit). To exit the Sleep mode, press [Energy Saver] and confirm that the Energy Saver light is off.
  • You need to log on as an administrator to perform this update.
  • Make sure that no other applications are running on your computer.
6. If [Found New Hardware Wizard] appears on your PC screen, click [Cancel] to exit the screen.
  • [Found New Hardware Wizard] screen may be displayed multiple times. Cancel anytime you encounter this screen while performing this update.
7. Double-click ?MF4150_FirmwareUpdateTool_V0xx.exe? that you downloaded and saved.
8. Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
9. Confirm that the machine is in the ready status, and then click [Transfer]
  • If the printer is not detected: Check if the printer's power is turned on and the USB cable is properly connected. Then click [Retry] to proceed.
10. The firmware is transferred to the printer.
  • Never turn of the power to the MF4150 while firmware is updating. If power interruption occurs while the firmware is being updated the control board will be damaged and will need to be replaced. The replacement of the control board and labor will not be covered under warranty.
  • If an error occurs while transferring the firmware: Check if USB cable is properly connected. Click [Retry] to proceed.
11. When [Firmware transfer is complete] appears, click [Exit].
The printer starts the update process automatically.
<ERASE FLASH ROM> appears on the printer's display while the existing firmware is being erased.
Then printer's display shows <FIRMWARE UPDATE> while updating the firmware.
When the firmware update is complete, the printer's display shows <FIRMWARE UPDATE OK> <MACHINE POWER OFF/ON>
12. Turn printer's power switch OFF, wait 2 seconds then turn the power switch back ON. Check that there is no error on the printer display. Reconnect removed fax line cable.
Jun 22, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Canon imge class mf 4150 e225 eroor?
First:
Try to get the latest firmware at LINK.
Here is how to:
8. . Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
Feb 23, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Dell 3130cn gone down with repeating 016-370 Error...
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
Jun 28, 2010 | Dell 3100cn Laser Printer
Error 79 ...shuts off and the screen says error 79
Hi angelahender:
Here is your problem.
79 Error
PowerOff>PowerOn
The product has experienced an
internal firmware error.
Disconnect the power cable from the
product, wait at least 30 seconds, then
reconnect the power cable and wait for
the product to initialize.
If the error persists, upgrade the firmware.
Firmware update via flash executable
The configuration page lists the firmware version of the product. On
flash-memory-based products, you can update the firmware code by
downloading the latest flash executable for the product and running
the program according to the readme instructions that come with it. If
the firmware should become corrupted or fail (usually because of an
interruption when attempting to update the firmware), the product will
no longer function. In this case, a firmware recovery DIMM is
available from HP.
Hope this helps
Jul 16, 2009 | HP LaserJet 3330 All-In-One Printer
Error code 79:04
From the service manual:
System Error: 79:04
Problem Description: Firmware Error.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer on again and check if the Error Code has disappeared.
The firmware upgrade and tool can be found here.
Jun 16, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
HP Color Laserjet Cm1312 Mfp Logo
Seeker5211
Seeker5211
