Question about Phil & Teds Baby Gear
Brake repairs I have P&T Explorer from second hand on my buggy the brake is great but when i try to unbreak I need to move the rod manualy on the right side is not moving back. Second think on the right side when I open the stoller the handle bar feel loose ( something not locking) after a while is perfect can you give me advise what happen how I can fix?
  • Phil & Teds Master
  • 1,629 Answers
Hi Erzseber,
We recommend you contact Phil and Teds directly for assistance Contact Us phil teds
Posted on Jun 12, 2014
  • 6 Answers
SOURCE: quinny zapp bar keeps dropping
It sounds like you put too much weight on the back of the buggy - handles at some point.
This happened mine too. it clcks into place but it doent stay up.
I looked intogetting it repaired but it cost too much - in myopinion
Posted on Sep 21, 2008
  • 18 Answers
SOURCE: buggy wont fold down
Problem suggests that you have not followed the user operation procedure correctly and hence damaged the folding mechanism.It is possilble you may have damaged locking gear of the folding mechanism on the left side while trying to fold the equipment sometime during earlier operation.You may like to consult a service engineer to fix the problem
Posted on Sep 08, 2007
  • 13 Answers
SOURCE: Bugaboo Hand Brake
the only way is to call directly to bugaboo because these are inner problems that have to be fixed (if it can) if the stroller is more then 2 years old you might have to go to your nearst retailer and order a new chasis for i it (there around 100.00 to 200 dollars. if you need the exact amount let me now and I can get it for you tomorrow the number for bugaboo is 1-800-460-2922 good luck
nathalie
Posted on Dec 10, 2008
  • 5 Answers
SOURCE: Main Chassis bar won't lock on one side
We had a similar problem, the right-hand hinge of the frame would not lock and the button was permanently down. What had happened was the handle extension switch housing had come unscrewed and slipped up the frame, causing a small spring to fall out. The lock switches each have a spring which pushes down on a rod inside the frame to lock the hinge. To access the spring, unscrew the handle extension housing and slide it up the aluminum frame. I replaced the missing spring and the frame works perfectly. If the problem is with the spring, this should work. Alternatively the problem may lie inside the lock switch housing, which contains a very simple mechanism which slides the lock rod up and down. This can be unscrewed as well. As far as I can tell, the actual hinge assembly itself is a sealed unit and can't be opened, but hopefully, you won't have to.
Good luck,
Ben
Posted on Jun 25, 2009
  • 3 Answers
SOURCE: Jane Powertwin Pro Buggy Problems
To lock the front wheel there is a small black button that can be twisted. It is very stiff on my buggy but if you fiddle with it while the wheel is straight it will lock it.
Posted on Jul 28, 2009
Lots of shaking from side to side.
Could be a bad tire ( or bent rim Have balance checked), ball joint, idler arm, wheel bearing, steering tie rod end or defective rack and pinion unit. Lift vehicle about 1 inch off ground ( do each side independently) Use a pry bar and pry from ground up and down on wheel. Much play? bad ball joint. With both hands, try to move wheel side to side. Much play? could be a tie rod end or bad wheel bearing. Visually check play of steering arm into rack and pinion unit, more than about a half inch play, bad rack and pinion unit. Try to move back and forth with hands top and bottom. Much play? Bad ball joint or wheel bearing, verify visually that it is ball joint moving, else it is the wheel bearing. Manually check for play in each joint in steering control rods from steering knuckle all the way through each rod where there is a joint. Replace the one you find excessive play in. Check mounting studs for sway bar for loose fit, deteriorated rubber bushings or a crack / break in the sway bar. Replace if needed. That's about all I can think of unless it only happens when applying brakes, in which case it could be a warped rotor.
Aug 21, 2014 | Cars & Trucks
The rod connected to the needle is not moving up and down anymore. I was sewing a straightline at setting 2 when the rod just stopped. We romoved the top and side pannel. Then we turned it on to see if the...
Easy fix is take to local repair person, but barring that you will need to look to replace the little knob so that it tightens down and grabs the larger knob. Sometime you'll need to try to place it on the machine a few different ways till it works right.
The little knob is used to disenage the machine for winding a bobbin. Add little bit of machine oil to help keep it loose.
Dec 17, 2010 | White Sewing 1766 Mechanical Sewing...
Abs light and hand brake light on
mine did the same to me today. Any help on this would be great
Feb 01, 2010 | 2004 Jeep Grand Cherokee
2000 caravan drivers side rotor wears out told tie-rod true or no
Look behind front wheel for rod that attaches to spindle/knuckle, and moves your wheel back & forth from steering rack. The tie rod (outer) is the piece attached on the end, that is threaded on that rod, and attaches to the spindle/knuckle, behind the wheel. Grab your tire and try to wiggle it hard from side to side. (hands at 3 & 9 o'clock ) Push with one hand while pulling with the other. If there is slop, or play, you have probably got a bad tie rod end, which you can observe it move by looking at where it attaches, while someone else wiggles it. Maybe this picture will help you I.D. it.498e60a.jpg
Jul 29, 2009 | 1988 Dodge Grand Caravan
Looking for replacement wheels for chicco stroller
There is a company called Buggy Pit stop which valets as well as repairs pushchairs. I used them when i gave my old dusty broken pushchair to my sister. I had it repaired and valetted by them. They did a great job and they were not that expensive either.Hope this helps. Their number is 020 8861 0038.
Jul 02, 2009 | Chicco Ct 0.1 Explorer Standard Stroller
Have a 95 ford explorer and the rod needs to be replaced
If the repair is going to cost more that half the value of the vehicle, it is not worth it. In this case, I'd don't think this is worth the cost
Apr 02, 2009 | 1995 Ford Explorer
My 1996 taurus has a wobble with the front right wheel
the only rod i can think of is called a radius arm ....it goes from the front crossmember to the lower control arm
Mar 20, 2009 | 1996 Ford Taurus
Need a Safety Clip for phil & teds Explorer - where would I get one from
I have a problem with my buggy how do I get it resolved?
Your first step is to contact your original place of purchase. The retailer has a great knowledge of our products and will be able to arrange a repair/replacement part where necessary.
If the product fails in the first year of ownership due to a manufacturing fault we will repair it free of charge. If it is not practical to repair it we will replace it.
If the product fails due to wear and tear, accident or negligence, or if it is outside the warranty period, we will happily repair it for a reasonable charge. Please note as outlined in your instruction booklet the customer is responsible for freight charges if the product is required to be sent to our repair agent.
UNITED STATES OF AMERICA
Distributor
Regal + Lager
1100 Cobb Place Blvd
Kennesaw GA 30144
USA
Tel: 770-955-5060
Fax: 770-955-1997
Website: www.regallager.com
Mar 28, 2008 | Phil & Teds Kiwi Explorer Jogger
Baby Gear Logo
154 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Bill Boyd
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
