Question about 5303L Security/Remote Start System
Got a 2008 g6 it got code u0100 ECM/PCM don't crank at all got power I take out the car battery for like ten min that alli did
Don't crank on a error on dish after taking battery off for ten min
I HAVE A TOYOTA CAMRY HYBRID 2011 MODEL, PLS DOES ANYONE KNOW THE MEANING OF THESE CODES AND WHAT I CAN POSSIBLY DO TO SOLVE THEM, U0100 AND U0001
code U0100 refers to a control area network(CAN bus) problem some where in the CAN bus network an electrical connector , wiring harness, , module has failed or a computer has crashed
The code appears when there is a serious situation where the signals between the electronic control module (ECM) or the power train module (PCM) or a particular module has been lost
It is not a common problem and is most likely a failure in the ECM or the PCM or the transmission control module (TCM)
bent or pushed out pins , loose ground ro the computer or jumping a dead battery or crossing the terminals while jumping will destroy a computer
code U0001is the high speed communication (CAN bus ) between modules . can be from bad connections , loose wires , disconnect battery , dead battery or wrong jumper application a good scan tool will detect any faulty control modules so use it to find and fix the faulty module or wiring
for more interesting advice just go to your browser search bar and type in --how to repair code U0001
or
code U0100
or
any other codes that you need help on
Dec 02, 2017 | Toyota Cars & Trucks
Try these write ups I found. It is too much to reprint and it gives credit to the author.
http://www.troublecodes.net/ucodes/u0001/
http://www.troublecodes.net/ucodes/u0100/
Dec 02, 2017 | Cars & Trucks
How do i fix error code u0100 on my 2009 saturn aura xe?
That sounds an awful lot like the ECM is having trouble. Since the model year is nearly 7 years old, it is possible that the ECM is toast or that a wire or two has a corroded connection. Have a look at this information: http://engine-codes.com/u0100_saturn.html
Hope this helps.
Jun 29, 2015 | 2009 Saturn Aura
Toyota codes u0100 and u0101
U0100 means lost of communication with ECM/PCM
U0101 means lost of communication with TCM
Feb 24, 2014 | 2007 Toyota Camry
I got in car wouldnt crank then today security light came on usually can wait a while it will crank anything i can do to override this issue
yes undo the battery and leave off for five to ten mins then attache cable back to battery that should clear the computer
Jan 28, 2014 | 2002 Saturn S-Series
I have a 2001 oldsmobile sihouette I disconnected negative battery post for ten min then put back then I parked van now when I go to start it securety lock is on and I can't start car and it reads cal...
you have to do that cycle 3 times,battery needs to fully charged.
Hood to stay closed,doors also(roll down the drivers window)
Kill the DRL headlights if possible(try putting the E-brake on)
Crank and leave key on,10 min or till light goes out,then key off,,no need to wait 5 min here,crank again.leave key on,,,,,3 times.
By the way,disconnecting the battery in that vehicle will not do anything like clear codes or memory,may need the radio code in the owners manual also.
Jan 07, 2014 | Cars & Trucks
2006 VW Jetta code U0100
This problem is with ecu / ecm= engine control computer. These are a common and horrible problem on vw's, particularly on tdi's. The signs in a tdi are when car dash lights come on, but no glow plug light,trans gear lights flash, but car still tries to crank. And hopefully ecu has enough power to out out code u0100= no communication with ecu. Unfortunately the ecu will need to be replacd. The ecu is located under the hood, near and under the wipers. Used ecu with same codes run $50-200. New $1000. If get used one make sure has a return policy. codes must match production quarterly year.
Apr 14, 2013 | 2006 Volkswagen Jetta
5303L Security/Remote Start System Logo
27 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
