Question about CyberPower Computers & Internet
300 watt manual
How to select right ampire battery of 300 watts ups
  • 1,162 Answers
Your not asking the right question. The answer is dependent upon how long you want the backup to work. Does a battery fit in the unit or is it alone? If you were to connect a car battery to the unit it would run for many hours, say a motorcycle battery would run maybe an hour. It is all about the time you want for run time.
Posted on Mar 30, 2014
HOW MANY WATTS DOES THIS MACHINE HAVE IM TRYING TO USE A 1440 WATTS INVERTER AND 24 V BATTERY ITS FAILING TO INITIALIZE??
With a 1440 watt and 12 volt, the battery must be over a thousand AH. (ampere/ hour) because for the 1440 watt, you need a current of more than 100 ampere. But even with a few hundreds of watt, you need a very powerful battery, because 300 watt, will pull 30 amps from the battery. A car battery with even 100 AH can't deliver that.
Mar 23, 2015 | Ricoh Aficio 2018D All-In-One Laser...
Does Malibu still make a model number ML500TW timer transformer
Intermatic/ Malibu series lights are available 44 watt, 88 watt, 100 watt, 121 watt, 200 watt, 300 watt, 600 watt, 900 watt.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
None of the other brands sells 500 watt either.
Kichler sells 300 and 600 and 900Watts
Paradise does not have 500 watt
Malibu brand does not carry 500 watt
Portfolio does not carry 500 watt
Apr 16, 2013 | Hardware & Accessories
Hemco 6503HBLC 300-Watt Touch Dimmer defective
So long as you only use incondescent lights as it says on the switch and on the packaging you won't blow up the switch. the 300 watt is the maximum amount of lights you can have in total on that switch too. five 60 watt light = 300 three 100 watt light bulbs = 300
Mar 20, 2013 | Electrical Supplies
I replaced an old Malibu 300 watt powerpack with a new digital 300 watt Malibu power pack and when I turn it on it runs for about a miniut and then shuts down. I have 15 11watt light on it, the same as the...
300 watt power pack should have 300 watt load.
You have 165 watt load.
Copy following link for general tips to get Malibu power pack to last longer.
Problem might be the photo eye.
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
Rotate manual dial to ON position and see if lights turn ON.
Keep in mind the digital power pack has photoeye that is light sensitive, and must be exposed to dark light to activate.
For timed functions. Rotate manual dial until it points at timer. Press clock set function button, and use up-down buttons to set current time. Press timer ON button, and then use up-down to set ON timer. Then press timer OFF button , and use arrow keys to set OFF time.
This product has 1 year limited warranty, contrast with old-type analog power pack with 5-year warranty.
Malibu does not even post a manual on their site, which might have troubleshoot section to illuminate why your system has problem,
http://malibu.brinkmann.net/customer_service/owners_manuals.aspx
Nov 29, 2012 | Hardware & Accessories
I have a V-ampire combo and it keeps ;loosing the factory settings when it is unplugged form the mains can you help please
You need to make sure the decimal point in the display is NOT blinking and then press the IN/OUT key for over two seconds to save the preset before turning the power off. Refer to page 9 of your user manual for this information.
Jul 31, 2011 | Behringer V Tone GMX212 2X60 Watt Stereo...
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
I need instructions for setting the timer
Malibu product manuals
http://www.malibulights.com/customer_service/owners_manuals.aspx
Manual for 300 Watt power pack
http://malibulights.com/docs/pdf/8100-9300-01.pdf
Read cautions
Tips
300 Watt power pack requires sum of bulbs to equal 300 Watts
If you use 10 - 20 watt bulbs that is only 200 Watts so you need 200 Watt power pack
Replace burnt out bulbs immediately or other bulbs will burn out and shorten life of power pack
When working on bulbs, unplug power pack so it does not shorten life of power pack
Set Malibu Timer:
Red trippers are ON
Black trippers are OFF
Place trippers on dial at ON OFF times/ AM and PM
Set current time of day:
Plug in power pack
Trippers are installed
Rotate dial counter-clockwise to current time, say 9 am
Rotate dial 2 more revolutions and then return to current time
That's it
Oct 12, 2010 | Intermatic Malibu 300W Power Pack...
Timer will not tirun on the lights, it stops when it gets to the time to turn on.
Malibu home page
Malibu manuals
Try the manual override >>> un-plug power pack and try loosening manual override with WD-40
It sounds like the clock motor is unable to push the manual override
Don't continue to run power pack or the clock motor will burn up or break a plastic gear
If manual override will not work, or clock will not trip on lights, you need a new power pack
Power pack size chart and wire length
Be sure to buy same wattage power pack as you have
The 300 Watt unit is made for 15 - 20watt bulbs (15 x 20 = 300)
If you buy 600 Watt power pack and hook it up to 10 - 20 watt bulbs, it will burn out the bulbs
Manual also says to replace burned out bulbs ASAP or other bulbs will burn out.
Oct 09, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Can you hook up two 12 gauge cables to the power pack of the ML 300 RTW transformer. Power cable would run in different directions. Thank you Joe
Hello yes you can the Important thing to remember here is not to exceed the wattage that the transformer puts out.
Add up the wattage of each bulb that you are running and ensure that you do not exceed 300 watts.
for example a 300 watt transformer could drive
a. 10 - 30 watt bulbs
b. 20 - 15 watt bulbs
c 75 - 4 watt bulbs
Its also ok to mix bulb wattage for example I use 10 watt bulbs in the fixtures in the front of the house but also power 4 20watt spotlights from the same transformer.
Hope that helps
Feb 26, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
Computers & Internet Logo
81 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
