Question about Clarion CCA329 CD Changer Replacement Cable
Equivalent transistor i need the equivalent transistor that can mach with rjh3044
Equivalence transistor tt2206
Equivalent Sanyo 2S?5793
Features : I(c) : 10A, V(cbo) : 1600V
1. High speed.
2. High breakdown voltage (Vcbo=1600V, Vceo=800V, Ic=10A, Pc=65W ).
3. High reliability (Adoption of HVP process).
4. Adoption of MBIT process.
TT2206 equivalent circuit is 2S?5793, TT2202, JL6920, 2SC5446
Dec 19, 2016 | Televison & Video
WHAT ARE THE EQUIVALENT OF BF423 TRANSISTOR
Any high voltage low power pnp transistor. with the specs:
You really can find more and a lot quicker with Google. dc0e5c00-5b26-4e27-8053-b04e4586c4e9.png
Jun 23, 2014 | Nte S921TS Equivalent NTE288 PNP high...
BC179 equivalent Available transistor
I would use 2N3251 or 2N3251A. The hfe is 100 and since you don't mention the hfe rank of your BC179, you need to check if your circuit is hfe dependent and will 100 fit the design. http://www.futurlec.com/Transistors/2N3251A.shtml
Feb 12, 2014 | Nte BC179 Equivalent NTE234 PNP low noise...
Do we have a transistor which is equivalent to d718
NTE36 is allegedly equivalent.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 08, 2014 | Nte D718 Equivalent NTE36 NPN high power...
Transistor data sheet
www.alltransistors.com this link will help you solve your problem...just find the equivalent transistor ...problem solve...goodluck!!
Jan 06, 2014 | JVC Fm/am Receiver Model Rx-318bk Tested...
I want equivalent transistor for BD 6316
Click here to download the data sheet to this device and find a substitution.
Apr 14, 2012 | Philips Televison & Video
I need to know the datasheet for the horizontal's transistor for a tv RCA 32F531T, because I lost the replacement
Hello
The number of horizontal output transistor is [TL 035]. If this number is not available, you can use exact substitute after reffering it to transistor data book and equivalents. OK.
Jun 03, 2011 | RCA 32F531T 32" TV
Respected sir i want to know the equivalent of d1878 transistor
That is a Sanyo type of line output transistor, sometimes used in power supplies of PT03 style.
Equivalents include the very popular BU508DFY BU808DFI etc or 2SC5885, 2SC5387 etc
I would choose a BU808DFI as a substitute. Slightly higher current and power rating.
Dec 13, 2010 | Televison & Video
Horizontal cct transistor
Specs for a 2SC1258 Si npn 28W 36V 18V 5V 3A 200>C 250MHz - 15/250 manufactured by NEC in a TO128-1 packaging.
Replacement/substitute or equivalent would be BLW15, 2N5938 or a KT934V.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 29, 2008 | Televison & Video
Clarion CCA329 CD Changer Replacement Cable Logo
149 people viewed this question
Top Clarion Audio Players & Recorders Experts
xxxxxx xxx
 Mikey
Mikey
Robert Rankin
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
