Question about Samsung Galaxy Siii Gt-i9300 16gb Marble White Factory Unlocked Gsm I9300 S3 3g Hsdpa 850/900/1900/2100
Problem getting samsung s3 reboot system up when pressing volume up power and home botton
Problem getting reboot system up when pressing volume up power and home button
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Posted on Jul 04, 2014
How can I unlock my Samsung galaxy S3 because I don't know the unlock pattern or the email address of the last owner
Turn off your device. Press and hold the power, volume up and home buttons. Use the volume buttons to Factory Reset, confirm it, then select the Reboot option the same way.
Oct 18, 2016 | Samsung Galaxy Siii Gt-i9300 16gb Marble...
My samsung S3 mobile is frees and not turn on kindly give me solution
this will wipe your phone and any glitches that may be associated with it:::sgs3 hard reset or reset Galaxy S3: PRESS AND HOLD VOLUME UP + Home Button + Power
Turn the phone off
Press and hold Volume UP and Home (center) button
Press Power until the phone vibrates
Wait until you see the Android logo then release all the buttons
Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side)
Select YES...delete all user data with VOLUME DOWN and then Press Power
After format, press Power again to reboot the phone (select reboot system now)
Feb 26, 2015 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
Restore factory default setting samsung GT-19305
Warning! All data will be lost after hard reset.Please make backup first.
1.Power off your phone
2.Press together volume up + home button + power button until you will se Samsung logo on the screen
3.Select with volume buttons "wipe data/factory reset" and press power button to confirm
4.Select "yes" and press power button to confirm
5.Wait until format is complete
7.Press power to confirm "reboot"
8.Wait until the phone restarts
That's it!
- See more at: http://factory-reset.blogspot.ro/2013/11/samsung-galaxy-s3-4g-i9305-hard-reset.html#sthash.IRpj0Oyt.dpuf
Aug 15, 2014 | Samsung Cell Phones
She won't tell me why?.
If you are trying to access her own personal data on the phone, you may be out of luck - that's the point of having a pin number.
If you want to use the phone for yourself, you can do a hard reset.
Turn the phone off.
Press and hold VOLUME UP and Home(center) button
Wait until you see the Android logo then release all the buttons.
Select YES -- delete all user data with VOLUME DOWN and then press Power
After format, press Power again to reboot phone. (select reboot system now)
May 31, 2014 | Samsung Galaxy S3 III I9305 LTE Unlocked...
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
How can i reset my phone with the emergency call screen,i locked myself out my phone
Apr 21, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
The flight mode setting in my samsung galaxy gt19003 i could not remove it.. this is un able me to make calls and messaging even my wifi net work are unable to access.
try to restore it
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
this one note all files will be deleted
Mar 01, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Galaxy s3 won't turn on fully
Hello Sarah,
You can try these solutions:
Solution 1: Soft Reset(no data loss)
  1. Take out the battery and leave it there for 5 minutes.
  2. Reinsert the battery.
  3. Press and hold the power button for 10 seconds.
Solution 2: Replace Battery
  1. Take out your battery
  2. Insert new battery that you found from a friend or family with same model.
  3. Power on
  4. If it works,buy a new battery
Solution 3: Hard Reset(you will loose your data)
  1. Switch off the device.
  2. Press and hold Volume Up + Home Button + Power Key.After 2-3 seconds, release the Power Key.
  3. You will enter boot screen,use volume buttons to navigate and select Select Wipe Data / Factory Reset and then press power key.
  4. Select Yes.
  5. Reboot your device and wait to power on.
If nothing works you have to take it to your supplier.
Nov 28, 2013 | Samsung Galaxy S3
How to break the lock code for the Samsung Galaxy s3
1. Power off phone
2. Press and hold Home Button ( middle ) + Volume Up + power on button
3. Wait for 5 second until Android System Recovery menu appear
4. There are 4 options
  • reboot system now
  • apply update from sdcard
  • wipe data/factory reset
  • wipe cache partition
5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
Jan 13, 2013 | Cell Phones
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
Samsung Galaxy Siii Gt-i9300 16gb Marble White Factory Unlocked Gsm I9300 S3 3g Hsdpa 850/900/1900/2100 Logo
53 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
