Question about Makita Hammering
Makita breakers replacement armature
4 Suggested Answers
SOURCE: something wrong with the armature
If the armature is shot, it will spark a lot where the brushes are touching the armature comutator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good . That's Makita special, they don't make it good as they used to. The price for new grinder is about $130, for armature $65. field $40
Posted on Mar 08, 2009
tooltech75
  • 80 Answers
SOURCE: How to replace main bearing in a Makita GA5000 5'' angle grinder
i used to grab the armature and tap the housing off with a rubber hammer...
try tapping in opposite corners every time....
when it does fall have a cushion ready on the bench or floor to catch it...
Posted on Oct 03, 2009
tiberiann
SOURCE: armature problems
http://www.toolsandmachinery.com/blog2/tag/repair-9564cv-grinder/
Posted on Jan 12, 2013
Makita bhp454 overheated, not turning clockwise.
It is very common for the armature to overheat and melt down.
Open it up and inspect the armature, it will be very obvious it is burnt.
If it is the case, replace the brushes (#16) and the armature(#14)
Makita BHP454 18V LXT Lithium Ion Cordless 1 2 Hammer Driver Drill Parts
Dec 03, 2016 | Makita Drills
Makita grinder keeps tripping circut breaker
FIRST OF ALL !!
Control where the tool is used first for undervoltage on the mains supply group.
If it is everywhere a problem FIRST replace the circuit breaker.
After that control all connectors last check interference suppression capacitor.
If all are controled , relace armature or electric field or both.
Aug 19, 2016 | Makita Saws
How to remove field coil from makita hr3000c drill/breaker
Here is a parts breakdown for your drill. Of course the armature has to be removed first. There are two screws holding the field. It should just push out at this point. If not, the housing may be melted to it. Good luck with that. https://www.ereplacementparts.com/makita-hr3000c-rotary-hammer-parts-c-97_380_507.html
Jul 14, 2016 | Makita Drills
Brushes arcing
Brushes arc for several reasons. If the spring over heated and lost its tension or the copper line from the brush to the cap broke/burnt off or the brush wore down too far to be pressed on the armature properly. The replacement brushes you need are Makita part number CB-124. If you still have exessive sparking after replacing the brushes you may have a bad commutator on the armature. The only way to fix that is to replace the armature, Makita part number 512831-0.
Oct 09, 2012 | Makita 5005BA 5-1/2 inch Circular Saw
Makita 2012nb replacement motor
I have a service center for Makita tools and the only way to fix or replace the motor is to buy the parts you need, in this case the armature (PN 516811-8) and field assembly (PN 526101-1). You can go to a site like www.ereplacementparts.com or any other aftermarket site to get them or try finding a local Makita repair center and find out how much it would cost to get the parts through them.
Aug 27, 2012 | Makita 2012NB Electric Planers
Smokes coming out from the grinder and the machine does not spin
this indicate burned field or armature coils, repair or replacement necessary
Feb 03, 2011 | Makita Angle Grinder 4.5" 9524NBX
Gears seem to be skipping. which of the 2 gears is most likely to wear? the one on the armature? or the big disk one?
If one gear is damaged it is causing damaging to the other, whether you can see it or not. If you have teeth that are skipping, the gear with bad teeth will wear out the teeth on the other gear. You should always replace both gears. On your polisher, the small drive gear isn't on the armature, it's part of the armature (Makita part number 515266-4) and that's a $90 to $110 part to replace. The spiral bevel gear (Makita part number 227455-6) is $40 to $45. You can replace one or the other but the gear you leave in will only wear out the new one.
Jan 31, 2011 | Makita PW5001C 4'' Variable Speed Electric...
BURNS OUT BUSHES QUICK WITHIN MINUTES
you have a armature problem I would think, look into the brush tube and try and spin the armature and look for discoloration on the commutator bars.
May 21, 2010 | Makita HM1800 64 lb. Breaker Hammer AC/DC
My makita hmo860c breaker drill has stopped working power light is on ?
I purchase a rotory hammer on ebay and it was listed as a makita, i was trying to get a spare part for it from makita. I gave them the information that is printed on a lable on the side of the drill, 66015c, 850W 110V,26mm and to my suprise they told me that it was not one of their drills, I have a few of these drills still being sold on ebay as makita. is there anyway that anyone can help me with this query.
Aug 30, 2009 | Makita Hammering
Something wrong with the armature
Mar 06, 2009 | Makita 9005B 5" Electric Angle Grinder
Hammering Logo
63 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
