Question about Speed Queen AES28AWF Electric Dryer
Speed queen electric dryer heats for about 8 minutes then heat goes off and does not come back on
Duct is clear. original heat seems good but not super hot.
  • jim gerber
    jim gerber Mar 25, 2014
    to be precise the heat goes off after 4 minutes and comes back on after 9 more, then repeats the cycle
  • jim gerber
    jim gerber Apr 01, 2014
    It turned out to be an intermittently faulty fabric selector (high vs. low heat) switch. To restate the symptoms: Dryer runs but clothes don't dry; heat comes on for a bit then turns off and may (or may not) come back on after dryer cools down a lot. The thermostat near the blower controls electricdity to the element so that was our first suspect. The thermostat had connectivity when cold and no connectivity when very hot as expected. After the air began to cool, the thermostat should again allow current to run through it (connectivity). While we did have connectivity at this point (and thus a properly functioning thermostat) we did not have electricity through it. So we surmised that we must not have had electricity to it and looked further back toward the electrical source. At the fabric selector switch we found a blackened connector. When wiggled, the connection would become intermittent. So when cold the connection was good enough to allow electrictity through it, but when expanded by warmth (or being jiggled by the vibrations of the drum), the circuit was broken. Replacing the fabric selector switch has now solved the problem.
    Problem Solver:
  • 5 Answers
The duct may be clear but the exhaust on the back of the dryer may be blocked. You have to take the back off the dryer and check where the blower is. Good luck.
Posted on Mar 25, 2014
  • jim gerber
    even with the duct removed the problem remains: the heat goes off after 4 minutes and comes back on after 9 more, then repeats the cycle. Now suspecting a faulty cyclic thermosat.
  • ramar13579 Mar 25, 2014
    It could be a faulty overtemperature sensor or the channel on the back of the dryer where the blower is located. I have removed about $7.00 worth of change and a handful of lint from one dryer.
  • 77 Answers
SOURCE: dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
Posted on Mar 12, 2010
SOURCE: speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Posted on Jul 28, 2008
heatman101
  • 43501 Answers
SOURCE: Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
  • 1267 Answers
SOURCE: dryer wont heat where is the fuse? speed queen
I do not believe it is a fuse, the dryer has a heater coil very much like a space heater contained in an air box inside of the dryer. If this heater coil breaks or burns into, then no heat. My 30 year old dryer has had two That I had to replace over the years. in order to get to this coil, youhave to take the back off.
Posted on Dec 28, 2010
  • 4348 Answers
SOURCE: I have a speed queen electric dryer model number
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
Posted on Mar 04, 2011
Problem is blowing cold air not heating up,its a speed queen dryer on bottle gas ?.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 14, 2011 | Speed Queen Dryers
Dryerwill not heat. Heating element was checked and it is good. Model # AES28AWF
heatman101;
Aug 06, 2011 | Speed Queen AES28AWF Electric Dryer
My speed queen model# AES68AWF doesnt heat what could it be?
heatman101
Jul 16, 2011 | Speed Queen AES68AWF Dryer
My speed queen dryer model #AES68AWF doesnt heat what could it be?
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
Dryer heats up for a few minutes and then quits but dryer still runs
Hello
When the dryer heats for few minutes and then it won't work it means that the thermal fuse is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this fuse for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer works but no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 21, 2010 | Speed Queen AES17AWF Electric Dryer
My speed queen gas dryer comes on but will no longer heat. The igniter is fine.....passes the Ohm test. What might be the solution? And what are the est. part costs....this is an old speed...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It works on amps... not ohms...
heatman101
Sep 07, 2010 | Dryers
Speed queen electric dryer shorted circuit bracker
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | Speed Queen AES28AWF Electric Dryer
Maytag Neptune MDE5500AY Heats intermittently
the herating element might be going bad. disconnect power, remove and inspect the heating element. look to see if its getting thin at any point. as it heats it could be seperatring and only give heat when it cools completely
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Speed Queen AES28AWF Electric Dryer Logo
164 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
