Question about Acer Aspire M3450 Desktop Computer
Usb\root-hub vender id 0x1002 product id 0x4397
  • Acer Master
  • 27,725 Answers
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Posted on Mar 25, 2014
Usb mouse not working
Solution is to re-install USB Root HUB > Make sure you disconnect all USB devices before you follow these directions. Use a PCI mouse and/or Keyboard to do the following. You may try using a USB mouse, but often times you'll uninstall your mouse's USB Root HUB before you completely uninstall all the other USB Root HUBs making your mouse useless. Follow the steps in the link over and over until all USB Root Hubs are uninstalled. Restart your PC and then slowly add one USB device at a time.
Side notes: Keep in mind if you have way too many USB devices you will need a Powered USB HUB. You can buy them cheap, and they are worth it. Often times folks plug more USB devices than their motherboard/power supply can handle or they rotate like 40 devices on one PC. Rotating is OK, but you might want to follow these steps to make sure your PCs USB is working OK.
The link:
DriverFinder We Make Drivers Work for YouPC Driver Tips Tweaks to...
Jan 17, 2014 | ASUS G50 G50v G50v-x1 G50vt-x5 Series...
Tip
USB DEVICE DOES NOT recognize
Issue:: USB DEVICE DOES NOT recognize
___________________________________
Manual Troubleshooting for this issue::
-Open device manager
-Right Click on USB Root Hub
-Choose Properties >>Selet Power Management
-Remove the Tick Mark Before "Allow the computer to turn off the power if device is not in use..."
-Do the same for all USB ROOT HUB
-Then Uninstall all USB ROOT HUB
-Restart your computer , USB device will be working.
on Jun 21, 2010 | Computers & Internet
Tip
Resolving intermittent Windows USB device issues
PROBLEM: USB Devices (Both internal and external) work intermittently.
DISCUSSION: Issue is caused by Windows power management disabling the USB Root Hub to save power (This option is on BY DEFAULT in all Windows installations)
RESOLUTION: Open Device Manager, scroll down to the USB Root Hubs Listings (There may be as few as two most I've seen is 7) Right click each hub, select Properties on the drop down menu, then click the POWER MANAGEMENT tab. There you will find a check box to allow windows to turn off this device to save power. Uncheck the box and close the window, repeat on remaining USB Root Hubs, then reboot.
This will resolve most intermittent USB device issues.
on Dec 03, 2009 | Computers & Internet
Device on USB 2.0 Hub
Hi! I suggest you to go here http://download.cnet.com/USB-2-0-Root-Hub-Device/3000-18493_4-81305.html to download for free USB 2.0 root hub device. Just click on DOWNLOAD NOW. Thank you for using fixya! I hope I had helped you with your problem! May you have a good day!
Mar 23, 2011 | Nokia Lands Phones
Epson scanner quit working
Goto your Linux configuration utilities and configure your printer again,sometimes after a crash the drivers are reset.
Utilities differ under different flavours look and see if you can do this
Feb 04, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Is there a compatible USB-PCMCIA card for the DV1000 by HP? None of the ports work on my son's hand-me-down computer and he needs at least one for printing. The geek squad wants $150 and for that, I'll...
Here ya go, $13
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124011&cm_re=pcmcia_USB-_-15-124-011-_-Product
ALso, try this
Go to device manager, usb root hub, right click, properties, power management tab, uncheck the box allowing windows to turn the device off to save power, repeat on all usb root hubs, reboot, see if USB ports work.
Nov 29, 2009 | HP Pavilion dv1000 Notebook
Cant access Logitec clicksmart 510 in ubuntu 9.04
Use a separate card reader to download your pictures.
Aug 27, 2009 | Logitech ClickSmart 510 Digital Camera
USB Hubs won't install
Please install the usb hub power surge patch from www.dell.com/support
Aug 24, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
G700 sony ericson - USB connection problem
hi ths is dacs
Try to format your memory card... that is the result of not safly removng ur phone from ur pc.. it usualy afects the memory card...
format the card using ur phone..ok...
Jan 03, 2009 | Sony Ericsson G700 Unlocked GSM Smartphone...
Acer Aspire M3450 Desktop Computer Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
