Question about Mitsubishi Office Equipment & Supplies
How to put print paper and ribbon
I have a problem how to put a print paper and ribbon in my easyphoto MT1
I cannot get the calculator canon MP121-DH to print on the paper roll. Any suggestions
This paper will only print on one side. Try flipping the roll over so that it tries to print on the opposite side.
Oct 29, 2014 | Office Equipment & Supplies
My 510s is having issues with printing. The print ribbon is sticking to the paper, thus tearing the ribbon and causing a paper jam.
Remove any slack in the ribbon by turning the ribbon-tightening knob, or reinstall the ribbon cartridge...
First Turn the printer off, open the printer cover and remove the jammed paper if paper is jammed..
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Unknown Hiti P510s 6 Dye Sub Roll-type...
Have a olivetti 1000S typewriter, put in a new cartridge but when I type no printing appears on paper, any ideas
Put a multi part form in it, if it prints on the copies then you have a ribbon issue. If so be sure the ribbon is installed properly and that it isn't twisted (the dull side should face the paper) Try it without the Lift off they sometimes steal the impression.
DickyO
Oct 07, 2011 | Olivetti Lettera 25 Typewriter
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
It printing but with black forms on paper
black form because of ribbon is touching to the paper for this solution is adjust head gap of the printer or put the leaver in 3+1 setting ...and try ....
replace the ribbon mask ..........
Dec 10, 2009 | Epson LQ-2090 Matrix Printer
My printer giving blank paper in epson lq2090 dot matrix printer
Either your ink ribbon is worn out or it is broken, or it is put in wrong, or your print head isn't working. Pull the print head the whole way toward the paper (With the adjustment lever) and run a test sheet. Look at it closely. If you see imprints, it's the ribbon. Id you don't, it's the print head.
Sep 03, 2009 | Epson Office Equipment & Supplies
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
24 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
