Question about Thule 2000 Dodge Dakota - Club cab - Xsporter Truck Rack
Timing belt truck got hot now motor turns over but engine sound like its out of time
What engine? Timing belt problem? Bent valves? Warped head, blown casket? These are suggestions as a possible cause. If you know you have it in time, do a compression check on all cylinders first to determine if there's an internal problem. It's a starting point to help diagnose.
Posted on May 19, 2014
CAR STALLED. DISCOVERED TIMING BELT HAD BROKEN. REPLACED BELT. STILL WILL NOT START BUT WILL TURN OVER
It sounds like the timing is still off, which will not allow it to start, or you have a faulty cam, or crank sensor.
Apr 14, 2011 | 1993 Volvo 850
Car stalled and will not restart. Makes a whirring noise when you try to start. Toyota Rav 4 1997
If the engine is turning over much faster than usual when you try to start it, you may have a stripped timing gear or broken timing chain/belt.
If it is not turning over at all, the starter motor is not engaging the flywheel.
Mar 23, 2011 | Toyota RAV4 Cars & Trucks
2000 ford escort zx2 quit running on the wife this morning still has electric\r\npower starter sounds like it turns but it will not start dont sound like ti turns motor over never heard of a start problem...
Pull the upper timing belt cover, just some 8mm bolts, and verify the if the engine is turning or not. If the timing belt breaks it will sound like the engine is spinning faster with the starter than normal. The great thing is that these engines are non interference and will not suffer valve damage if the belt breaks. If the engine is not turning with the starter then you have a bad solenoid in the starter and it will have to be replaced. You can check my profile for information on how to do the timing belt yourself if it comes to that.
Jan 11, 2011 | 2001 Ford Escort ZX2
I have a 1991 mitsubishi 3000gt and it wont start. the motor turns but not sound of it even trying to start like turning over. i see the belts move but no sound as if its even starving for gas just belts...
http://www.fixya.com/cars/r7030578-engine_turns_over_but_wont_start
Here is a link to a tip I wrote nate. It sounds like your timing belt slipped a tooth or ten. Or it may be broken. Does the starter motor seem like its turning the motor much faster than it normally does? You say that you can see the external drive belts turning, if this is true then your starter is engaging correctly. If your timing is off, or belt is broken, the engine will not make compression. Put your hand over the intake while someone cranks it to see if you feel that intake stroke pull on your hand. Read my tip in the link above for lots more info.
Nov 28, 2010 | 1991 Mitsubishi 3000GT
Sounds like broke timing belt but timing belt is not broke i have the v 6 dohc motor
What or how does it sound like a broken timing belt? Is the engine knocking? If the belt is not broken, it might have slipped and the timing may now be off, enough to cause the sounds you're hearing.
Sep 22, 2010 | 2002 Kia Optima
2001 chevy s10 loses power, will not stall, restart runs better.
SOUND LIKE ENGINE GETTING TOO HOT.THAT WILL CAUSE LOST OF POWER.CHECK COOLING CLUTCH FAN IF IT HAS RESISTANCE WHEN ENGINE HOT FAN CLUTCH IS GOOD.IF FAN CLUTCH FREE WHEELS WITH NO RESISTANCE WHEN ENGINE HOT.FAN CLUTCH IS BAD.THAT WILL CAUSE ENGINE TO RUN HOT WHILE DRIVING.
Jul 23, 2010 | 2001 Chevrolet S-10
Friday it sputtered and shut off 2 times the thrid time I started it I gave it some gas and it drove for a few feet then started sputtering and smoking from the right side of the engine. I pulled over...
Have the water pump checked. The bearing maybe seizing up causing the pulley to jam and smoke up the belt. Also as the motor got hot from pump not spinning, may have caused the motor to shut down as an overheating precatuion.
Nov 16, 2009 | 1998 Plymouth Voyager
97 nissan maxima starting problem
You can easily verify broken timing belt with a quick compression test. I cannot think of another cause for that symptom.
Jul 27, 2017 | 1997 Nissan Maxima
1997 montero sport 3000 24valve v6
The most likely senario is that the water pump went bad which caused the overheating in the first place. Then after the engine shut down, the water pump seized up. When the engine was restarted, the timing belt started to smoke because the water pump, which runs off the timing belt, was not turning. Since the engine overheated to the point of shutting down, blown head gaskets are a possibility. Put a new timing belt and water pump on it and start it up. If it runs OK, you're good to go.
Jul 26, 2008 | Mitsubishi Montero Sport Cars & Trucks
Thule 2000 Dodge Dakota - Club cab - Xsporter Truck Rack Logo
59 people viewed this question
Top Thule Boating Experts
Tom Chichester
L Pfaff
L Pfaff
John Mabry
John Mabry
Are you a Thule Boating Expert? Answer questions, earn points and help others
