Youtube how to stop water siphoning out of tank on a push button toilet
    Master:
  • 435 Answers
Why did you post this?
Posted on Mar 30, 2014
Is there a way to change the toilet from front flush to top flush to accommodate the button on the top of the unit in the tank?
So did the top not come with the tank itself, is it a replacement? Or is it a tank where you can choose top or front flushing?
In my experience the mechanism for top flush is more complicated than front flush which just lifts the flapper. Take the top off and look. See if there is a link that can be taken from the front and clipped to the top. you state is has a 'self contained unit', so it doesn't sound like a standard lifting flapper, so you may well be able to choose.
Jan 01, 2016 | Home
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
My toto power gravity siphon won't stop running. Suggestions as to how to fix would be greatly appreciated. Cheer, Mark
You have a problem with your flapper not seating all the way so the water is not filling in the tank to lift the ball **** to shut off the water first make sure the flapper is ok
Oct 24, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet isn't siphoning fast enough. The water
take the uper cover fo the toilet. check for the chain, that chain goes to the balon with air that usualy goes up when water is filling in and stop the water.
so, check for that chain to be long enough (it can be regulated ussually). the problem relies that id the chain is too short the reservoir or tank of water cannot fill up to a 100% to siphoning fast enough.
Jul 29, 2010 | Kohler Cimarron 2-PC Elongated Toilet with...
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
I recently bought a Glacier Bay 303-635 All-in-One toilet. It was installed just fine, however everytime I flush the toilet the tank fills up to the water line, but the spout over the water line tube keeps...
Try adjusting the water level down about a half inch or so and see if that helps. It could just be siphoning. Otherwise the valve may be defective. Hope this helps.
May 11, 2010 | Home
Water continue to drip just a little after fill valve stops
Check the little tube the goes from the fill valve into the overflow tube. You NEED to have a good arch in the tube to prevent back siphon from the tank. If that doesn't work then check to make sure the flush valve flapper is completely seated without any of its port showing. If you see the slightest amount of the flush port then you need to replace the flapper. AS well as make sure none of the chain is getting siphoned into the port preventing the flush valve flapper from completely seating.
Mar 20, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
