Question about Car Audio & Video
Eonon problems Hi I have just bought a eonon ge01be and when setting it up for the first time I got to the D.A.B and chose the 200mhz so now my D.A.B does not keep a good signal if any . Is there a way of changing the signal setting... Thank you
3 Suggested Answers
Justen52
  • 6 Answers
SOURCE: wirless signal problem
Make sure there is no interference, such as microwaves or cell phones that operate at 2.4ghz. Do you have many thick inside walls between your router and your computer? You could try a signal boosting antenna to attach to your router.
Posted on Apr 22, 2009
  • 1514 Answers
SOURCE: hi, I bought a GARMIN
  • On the screen that says WHERE TO and VIEW MAP there's a TOOLS icon (Picture of a spanner.) Press it.
  • Then press SETTINGS, (the spanner icon) or on some models LOCALE (Blue Icon at the top left corner) replaces the SETTINGS icon
  • Press LANGUAGE (The lips icon)
  • On this page you'll see 3 items; VOICE, TEXT LANGUAGE and KEYBOARD
If you need to change the text language press TEXT LANGUAGE and select ENGLISH
To change the voice language press VOICE and select the name of an English speaking voice
If you need to change the keyboard layout press KEYBOARD and select English
If the text language is in Spanish you won't know which icon is which but press each one in turn and you can change each to English. This should solve your problem.
Posted on Nov 27, 2010
Iv just bought a eonon d2207 but when i insert a disc it wont fully go in any help?
Hi there, there are 2 transit screws at the top of the unit. Unscrew those. If it fully comes out then take them out, or else just unscrew it till its loose. This should solve your problem.
Aug 14, 2010 | Car Audio & Video
Hi ive got an eonon e1012 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i put in a cd...
hi, i bought eonon E1012 on Eonon official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.
I think maybe you have connect the wrong wire and have bum out the built in amp.
Nov 08, 2009 | XO Vision XO9013 Car DVD Player
Eonon 1025e screen mechanism broken. Need to replace two of the gears but cant find spares anywhere
Hi I have the same problem.E1025 unit has broken gears to make unit come out so just removed broken gears and manually pull out.Screen would fold up and down still until today .Now the other plastic gears have broken.I have tried to contact eonon to buy spares but dont wont to know about it.Now looking at old remote cars,video recorders etc to find something that will fit.No luck yet will let you know if i do. Eonon ****
Oct 02, 2009 | Car Audio & Video
Eonon faults
You have only conected the live feed, that will cause the light to come on but not switch on. You must conect the switched live feed as well, then it will turn on.
Good luck
Aug 07, 2008 | Car Audio & Video
Mac OS X 10.5 Install Problem
If it's at all possible overclock your PC.Have some one whose experienced and confident when they attempt it.If 200mhz is all the boost thats required,than you should be able to reach that requirement.Some PC's overclocking can't be done.On the other hand,you may have one that can.In case you are wondering what that means:Overclocking is pushing the engine(example) of your PC faster than the factory set it.In my eyes ,if the PC has adjustments in the Bios to make it faster ,then , why not give it a boost.It will work if 200mhz is all you need.Again only a PC tech. should do this.
Keep me posted!!
Jun 12, 2008 | Computers & Internet
My First RAM Upgrade-Any Tips
Ah you have found out one of the great things about confusing naming standards. Often times, 200Mhz memory is called 400Mhz if it is DDR because DDR stands for "Double Data Rate".
It still operates at 200Mhz speed, but since it doubles the data it is sometimes refered to (wrongly) as 400Mhz.
On the upside, all DDR-I ram is backwards compatible. So there should be no problems. However sometimes different memory sticks dont play well together.
What I would do is this:
1) Shutdown computer, UNPLUG computer - wait 5 minutes
2) Open computer
3) Remove old Ram stick and replace with the new stick
4) Replace cover, plug in and boot to windows.
If everything works fine, then do step 1-2 again, but this time add the old stick you removed before, and place it in the unused slot.
Again check that the computer functions properly. If it does not, remove the old stick.
Nov 22, 2007 | Gigabyte GA-8IGX Motherboard
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
