I have Bryant 345MAV furnace. Blower comes on but not ignite, after one hour it ignite but run for few minutes
Change filter, change battery
  • 306 Answers
SOURCE: ignition failure code on
Sounding like a flame proving device is failing to sense flame. Try to clean the device with some steel wool. It is located right next to the last burner looks like a thick wire. Take the steel wool and gently rub the carbon that has built up off. Should only take 4 or 5 strokes. Let me know it that did it. Ken
Posted on Dec 02, 2008
  • 12173 Answers
SOURCE: My Lennox gas furnace runs for approximately two
if the unit has a flame (gas valve opening)the problem may be the fan going bad or fan relay -- sounds like unit going off on high limit control
Posted on Nov 01, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Carrier Gas Furnace and Hunter Thermostat not working
Definitely a furnace issue. The gas valve is not opening if you see no flame. I have seen the igniter glow but not send enough voltage to the circuit board to make the gas valve open. If this is the case you should replace the igniter. It is very fragile so please use care when replacing. Check all connections at the circuit board as well as the gas valve. Check your gas supply. Check to see if you get 24 volts AC to the gas valve. If no, replace the circuit board. If yes, replace the gas valve once you confirm that you have gas to it. If you get a pilot flame only, you will need to clean the burners and flame tray that spreads the flame from one burner to the next.
Posted on Dec 06, 2009
  • 221 Answers
SOURCE: furnace ignites when thermostat calls for heat,
You don't say if the blower is coming on, no blower would cause the limit to open. By the way, the limit is internal and auto-reset, not the manual reset roll out switches on the burner assembly.
Posted on Jan 11, 2010
  • 4234 Answers
SOURCE: I have a gas furnace with electronic ignition.
Hopefully someone with more experience will respond as well, but my experience with this type of furnace is that this is likely to be a clogged line or gas feeder control device. The behavior indicates that there not enough gas being presented to the unit. Unfortunately this is NOT a DIY type of repair. A licensed plumber should examine this unit. Gas units can be dangerous if not serviced properly. Please seek local assistance frmo a professional.
Dan
Posted on Nov 20, 2010
Bryant Plus 90 furnace
possible your supply duct leak or break
Feb 11, 2014 | Heating & Cooling
P3UCD12NO7601A Not Working
Check all the thermal limiters on the combustion heat exchanger. They can go bad and shut off.
Dec 16, 2013 | Sport & Outdoor - Others
Bryant 345mav furnace shuts down early after one minute
Try to jump pressure switch as soon as the inducer come on and see if it stay longer. if it does you might have problem with draft or pressure switch itself defected.
Nov 28, 2013 | Heating & Cooling
Bryant 340mav036080 limit switch reset time
The primary limit switch in your furnace is an "automatic reset" switch, and should reset itself within a few minutes.
It is a safety device designed to prevent your furnace from overheating. If the furnace does get too hot, the limit switch opens and the burners turn off. The blower should continue to run until the furnace cools down again. The limit switch should then reset itself (usually less than five minutes).
If it will not reset, try tapping on the switch with a screwdriver or other tool. This will often un-stick it. If this does not work, the switch has failed and must be replaced.
A furnace will overheat for many reasons, but the most common are a dirty air filter (should be changed every 1-3 months), or a dirty evaporator coil (only if you also have central air). Make sure everything is clean and all your vents are open to help avoid this problem in the future!
There are other limit switches in the furnace as well, which are "manual reset". They will not reset unless the little red button on them is pressed. If one of these switches opens, it is best to call a contractor to evaluate your furnace, as an unsafe condition may exist.
Mar 02, 2011 | Heating & Cooling
Bryant furnace the ignitor does not get hot the furnace comes on ( the blower) runs for a couple of minutes then shuts down lower small blower comes on. the gas is released but ignitor is not glowing or...
Hello, if you have a multimeter you can check the resistance of the ignitor, if it is silcon carbide ignitor the resisitance should be between 40-90 ohms and if silicon nitride it should be between 11-18 ohms. if the reistace is not in this range replace the ignitor. Also, make sure the pressure switch is closing, if it remains open then the ignition seqence can;t begin
Feb 19, 2011 | Heating & Cooling
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Jan 23, 2011 | Bryant Heating & Cooling
Furnace comes on after two or three minutes off.furnace seems to run to often.
If the blower only runs it is likely due to a dirty filter or too many vents blocked or closed. Sencondly if the furnace runs more than you remember before installing the new thermostat look for an adjustment (sometimes called heat anticipation) and select fewer cycles per hour, this will allow a little lower temperature before it comes on hence fewer cycles per hour.
Mar 03, 2010 | Honeywell Programmable Thermostat Heater
Furnace ignites when thermostat calls for heat, runs for a few minutes and the burners extinguish, repeats... changed flame sensor, nodifference, saw 4 quick red flashes evry few seconds after burners...
Jan 11, 2010 | Goodman Heating & Cooling
Why Wont My Bryant Furnace Stay Running
Look on the blower door panel in the wiring diagram there should be a flash code but it sounds like the flame sensor is not picking up the flame and you may be able to clean it
Oct 28, 2008 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
