Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Have a samsung refrigerator model rb1955sw will not turn on no lights, fan, or compressor just FD in the front display
Has power, but no lights, fans, or compressor just FD in front display, Replaced main control board, display board and thermo fuses, no change. any help
  • 4 Answers
I think you might need to replace it and if you still have a reciet that could be usful or they might fix it just call up the store
Posted on Mar 25, 2014
SOURCE: Maytag stopped getting cold, buzzing noise every now and then after pwr outage
Frig requires either compressor relay or the compressor itself...should have some warranty still, so call an authorized servicer. Ray
Posted on May 30, 2008
  • 262 Answers
SOURCE: Maytag PBF 2255 HEW refrigerator JAZZ board replacement issue
thats different I was thinking of something else the board you are talking about just controls the temp. controls this may be your problem call1-800-688-9900 maytag or 1-800-253-1301 whirlpool they can give you a better idea on the part number issue this may be the problem
Posted on Jan 11, 2009
  • 306 Answers
SOURCE: Refrigerator not cooling: Maytag Plus: Model MSD2756GEQ
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
Posted on Aug 16, 2009
Macmarkus
  • 2605 Answers
SOURCE: Maytag refrigerator isn't cooling
Hi ****, Based on the discription you've provided it sounds like either a faulty start relay or the compressor is seized. If you have a multi- meter you can check the compressor to see if the windings are ok. Unplug the fridge. Remove the panel at the back down at the bottom. This should gain you access to the compressor. On the side of the comp. will be the start relay/overload assembly. Pull off the relay & overload and you'll see 3 pins in the form of a triangle. With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin. You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms. On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good ! If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit. This will start it if it's not seized also known as a "locked rotor".. You can find them at most brick & mortar appliance parts locations or on-line vendors. The package contains info on how to connect it. If that doesn't yield any results moving forward, let me know we'll go from there. **I suggest you phone Whirlpool customer support first though ( they own Maytag ) as they recently had a massive recall regarding the starting device of many compressor's and you may find your's to be included therefore have it repaired at no cost.** they will know by your model and serial number or if that isn't clear the number on the compressor. Good Luck Thanks for visiting "fixya", please take a second to rate my solution and leave a comment/testimony to it's helpfulness. macmarkus :)
Posted on May 02, 2010
  • 135 Answers
SOURCE: My maytag refrigerator the ice and water are not
check the water filter and water valve
Posted on Jan 12, 2011
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
I have a samsung fridge model rs2530bwp the fan nor compressor does not start , the board on the front door seems fine i can change temps with no problem and all the lights come on
Check out the defrost timer circuit - when that unit goes on, it disconnects power to BOTH the compressor and fans so the box will defrost. When cycle is completed or when a certain temp (via defrost thermostat) is reached power is restored to unit.
The thermostat also controls juice to the major components. If it is faulty no electricity is fed to the motors.
Jul 18, 2015 | Samsung Refrigerators
Why samsung refrigerator does not run model #RS261MDWP/XAA
if nothing is working - no fans running, no compressor running and no "clicking" sound of compressor trying to start, you probably have a defective control, which in your case probably means a bad control panel.
before trying to order one, unplug the frig and try to reset the panle.
Aug 18, 2014 | Refrigerators
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
Samsung model rs267 says OF on both temp displays
Freezer and refrigeration isn't working
There is no temperature indicating for Celsius of Fahrenheit it just displays OF.
The letters "OF" on the display of your refrigerator indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and the display returns to normal, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air. Thanks-Helpful?
Feb 07, 2011 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
My samsung refrigerator is 4 and 1/2 years old, the fan started making noise and the inside walls of the regrigerator and freezer were hot. one night it stopped working and there is no activity on the...
replace the compressor fan when it stops working the lines heat up also unplug your unit if it keeps running without the fan you will do damage to your compressor i suppose if you had no wear else to keep your food you would use a large portable fan to blow on the compressor bulb this is not a permanent fix and may only work till you get the new fan if you have any further questions message me back and please rememeber to rank how this opinion has helped thanks Rick
Jan 29, 2011 | Samsung Refrigerators
Compressor won't run- light turns on and fan runs.
Greetings.,
Since,I do not have a model number. I will go with most popular..remove the panel that covers the compressor. Please make sure its unplugged from power and remove the little plastic cover that goes over relay..(some do not have cover) being careful to notice how the relay comes off. remove relay and shake it. if you hear a rattle ..its bad...This is not always the case, but for the most part it is....NOTE:::if this is a G/E refrigerator...the compressor is off during defrost, but condenser fan runs and freezer fan is off as well...if so, find defrost timer and advance until compressor comes on..most located under front refrig kickplate or by thermostat(cold contol)
Jan 11, 2011 | Refrigerators
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Help?
turn thermostat all the way to the left to turn it off. restore power and see if it stays on and inside fan is running. Then turn thermostat to rite to turn on compressor. If the power trips when turning thermostat back on, the compressor may be bad. :(
Dec 27, 2007 | True GDM-41 Refrigerator
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
56 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
