Question about Zebra Symbol LS 3578 ER & FZ Accessories - P/N STB3508-C0007R Power Supply
3578 SCANNER BEEPS BUT DOESN'T SCAN
When it is on the charging dock, the green light is steady not blinking. The light on the scanner is not on
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Hello, My Kodak i1440 scanner is blinking a steady red light. The time I turn the scanner on, both green and red blinks once then the red light get steady. what possibly could be the reason? Thanks;
First you need to see if the scanner shows in the device manager , if it doesnt it is likely the CPU / Main board is faulty If you can see the scanner in the device manager it has connected and loaded its firmware in this case it could be many things but the image guides are the most common issue , check them for damage especially the white area on the underside
Sep 26, 2011 | Kodak i1440 Pass-Through Scanner
Getting blinking "red light" , doesn't scan
There are a few reasons this might happen. 1) Check if the transport lock is in the locked position. Unlock the unit if it is locked.
2) An error occurred. Try restarting the computer, unplug the scanner, wait 10 seconds and reconnect the scanner. (This fixes issues where the software isn't running/fully loaded or the connection isn't solid).
Try a new USB cable and a different port. If you have a USB hub in the middle, try a direct connection. (Bi-directional communication is needed and this may show as an error if it is lost.)
3) Try unplugging the scanner from power and plugging it back in.
4) Try unplugging the optional accessories. If they fail, the unit may indicate a failure.
5) The lamp may need to be replaced.
6) Something else may have failed. Consider if it is worth having the unit serviced.
I hope one of these ideas helps.
May 16, 2010 | Epson Perfection 3490 PHOTO Flatbed...
DS 3478 Will Not Power UP
make sure you have a 3478 cradle. We ran into that. We have 3478's and 3578's. You have to look at the gun and cradle to match up. 3578 replaces the 3478. Bless Symbols heart the two aren't interchangable. Can't tell the difference except on sticker.
Aug 18, 2009 | Zebra DS3478-SF Wireless Handheld Barcode...
Ups
Which ups do you have? The category you are listed in here says scanners. My ups has a steady green light when charged and it should never lose the charge until power is lost for 20 minutes. Please post back if you nedd further assistance with the brand model.  Steve Medley
Feb 15, 2009 | Umax AlphaVista Flatbed Scanner
Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Dec 09, 2008 | Xerox DocuMate 252 Path-Through Scanner
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
Blinking lights on standby, unable to scan
mi scanner no se puede instalar porque me sale un aviso de que debo tener firmado el software .
como obtengo el controlador para la instalacion en windows vista home basic
Mar 26, 2007 | Acer ScanPrisa 640U Flatbed Scanner
Zebra Symbol LS 3578 ER & FZ Accessories - P/N STB3508-C0007R Power Supply Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
