Question about Samsung Televison & Video
I need to know if tcon brd t400xw01 v5 crt1 bd 40t01 -c00 will work in samsung la40a450 c1 dxxy ver no aco3
    Genius:
  • Samsung Master
  • 1,039 Answers
None of these model number are correct. the model number and serial number and version numbers will be on a separate sticker toward the side. the correct model and version number will have to be supplied to get a correct answer. the model number will be called model code. I is very long.
Posted on May 12, 2014
Samsung UN60J62001AFXZC Ver No NS02 standby light continually blinks, will not turn on.
Unfortunately there is no way to know for sure if you received good boards also static can destroy a good board very easily unless proper static precautions are followed., one board you can basically eliminate as being defective is the TCON...its not 100% impossible a bad TCON board would do this but close to it. Do you have a volt meter by chance, it would be helpful to get some voltage readings from the power supply board pins
Oct 19, 2017 | Samsung Televison & Video
Replacement tcon board
There is no modification for T'Con boards. If it was a power board, you can do it. You should replace it with the original number.
https://electronicshelponline.blogspot.com/
Jul 24, 2016 | Samsung UN60EH6003 60" 1080p LED HDTV,...
Samsung LCD TV, no picture, but sound and backlights work. Not t-con board. Any ideas what it could be?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 05, 2015 | Samsung Televison & Video
Schematic of samsung la40a450 ci dxxy ver no ac03
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Samsung Televison & Video
The picture on my Samsung LA40A450 looks like x ray negative films and the screen is very White. It's two years old. What can I do
I hope our talented expert would have given you helpful info in chat session to solve tv problem, let me know if you still need further help.
Thanks.
Sep 25, 2010 | Samsung LA40A450 40 in. LCD TV
Hello, I have a Samsung LN-S4692D. The tv turns on, the back lights work, the audio works. The picture does not work. The screen is black and when I change channels or press menu it flashes however, the...
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
Apr 16, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Problems when switching on, keeps clicking on and off standby before coming on
Check power board for swollen capacitors and replace them. if that does not fix then remove the flat cables from the tcon board at the top. there will be no picture but if it comes right on replace the lcd panel. If it still is switching on and off replace the power board.
Mar 25, 2010 | Samsung LA40A450 40 in. LCD TV
Samsung bd-p1200 won't play new "quantum of solace"
I too had this problem with Qauntum of Solace, I could get past the teasers and the warnings but when it gets to the main menu I select PLAY and it just stops at 00:00. The firmware upgrade fixed it! However I had to make a CD because the LAN method said I already had the latest version. I downloaded Ver 2.5 from Samsung support site - ( http://pages.samsung.com/us/bluraysupport/support.html)
Then I needed to get Nero Burning ROM software (windows version) to burn an IMAGE of the .ISO file (I use a Mac and just burning the file onto a CD didn't work) You have to follow these instructions to the letter - ( http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=1488556&CDCttType=FM&ModelType=C&ModelName=BD-P1200&VPath=FM/200710/20071012103832890_BD-P1200_CD_Update_Process.pdf )
Finally the player recognized the firmware and did the upgrade to 081119_T22F_0924.07_XAA
Voila, QoS now plays without a hitch.
Apr 06, 2009 | Samsung BD-P1200 Blu-Ray Disc Player
Televison & Video Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
