Question about iPhone Apps
My remote isn't working
It has new batteries
  • Luke C
    Luke C May 26, 2014
    Hi Emma, do you mean your Apple TV Remote?
Remote isn't working for my Kohler C3-200
Sounds like bad remote that only works partially or some parts on toilet vent bad.
Apr 09, 2013 | Kohler C3-200 Elongated Toilet Seat
Are the batteries fresh and making contact at each end? Are the batteries free to move inside the case? If they are too tight they may not be making proper contact. I imagine they are inserted the correct way round!
Mar 14, 2013 | Televison & Video
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
I've just bought a new remote control as the original isn't working. Is there a set up routine that one has to follow?
If you bought exactly the same remote, then it should work without doing anything (just make sure it has batteries) if you bought a Universal Remote, you should input the codes for Panasonic first.
Sep 24, 2011 | Panasonic DMR-E55 DVD Recorder
Remote control won,t work
This is how to complete a remote reset for a Sharp television:
Turn off the television if it is on. Unplug the television. Please leave it unplugged. Take the batteries out of the remote control. Leave the batteries out of the remote control. Is the television still unplugged? Yes? Good leave it that way. Are the batteries still out of the remote? Yes? Good leave them that way. Point the remote at the television's remote sensor. Hold the power button down for 30 seconds. Release it. Press and release each button on the remote control. Plug the television back in. Turn it on with the power button on the television itself. Replace the batteries. Try adjusting the volume. Hopefully the remote works. If it still doesn't work the remote sensor on the television could have gone out or you may need a new remote. http://www.sharpusa.com may have a remote you can order or http://www.replacementremotes.com but if that isn't the problem you may or may not be able to return the remote.
Sep 23, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have a hampton bay remote that just stopped working. I have installed new batteries, have checked the code with another remote so I know the problem isn't the fan. The light on the remote does not...
If the light on the remote is not lighting when you push a button, check the batteries to make sure they are in the proper position. If one is turned the wrong way, the hand held will not work. You may also want to check the replacement batteries to make sure they are fully charged. If all this fails to solve the problem, you will need replace the hand held remote. Since Hampton Bay Fans are a house brand for Home Depot, they stock and sell replacement hand held remote controls.
Hope this helped you. Please let me know. Thanks.
Jul 13, 2011 | Hampton Bay Heating & Cooling
Batteries are good. However TV isn't on right channel to show any programming what to do?
Hi William,
To confirm if the remote control is working fine, aim the infrared emitter of the remote control to your cellphone camera, press any button key and check if the infrared will flash to your camera. Watch this video on how to do this trick.
Also, does the front panel button key of the TV isn't working?
Jdvillanueva
Jul 09, 2011 | Toshiba CT-9995 Remote Control
iPhone Apps Logo
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
