Question about Panasonic RRUS550 (512 MB 1425 Hours) Handheld Digital Voice Recorder
Can't open files on Mac OSX
Plug in on USB, open Finder, see only a list of small LNK files and no folders nor MP3.
  • 1 more comment
  • Caue Rego
    Caue Rego Mar 25, 2014
    I actually solved this using either the Terminal, ForkLift or anything able to __see hidden files__. You could also set up Finder to see them, such as using Secrets app.
    I just got no idea how to suggest this as a solution. I was just thinking in feeding here, when I asked this...
  • Rae Del Cerro Floreado
    Rae Del Cerro Floreado Jul 17, 2015
    The same happens to me. The first time I connected my voice recorder was to a Macbook. After that I couldn't see the mp3 files in any other computer. Now I have a Macbook pro, and I was disappointed to see that it also shows blank. How can we fix this?
    Rae Del Cerro Floreado Jul 18, 2015
    I fixed this just like you, following these instructionshttp://www.idownloadblog.com/2014/08/04/...
Don't have instructions on how to download music and apps to my mp3 MP828-8G
Make sure that the battery is fully charged. Connect the MP player (while it is on) to a computer with a USB Mini-B (5-pin) to USB type A cable. This is a standard charging cable for older cell phones and tablets.
With Windows, you should see an Auto-play option for what you want to do with the device. Choose the Open Folder to View Files (Windows Explorer) option. Assuming the original software is still on the MP828, install the Coby Media Manager onto the computer. (This file is labeled Coby-cometlite.) If auto-play doesn't launch, open My Computer/Computer by double-clicking on the icon on your desktop. Find the new removable drive and double-click on it.
For Mac OSX, you'll need to launch the Finder Window and look for the removable media. Open the Mac OSX Coby Media Manager folder. Then find the coby-mediamanager.dmg file. Install the software.
You can transfer files with the Media Manager after launching the CMM program. Since the Coby MP3 player works like a removable USB drive, you could also drag and drop files from one folder onto the Coby MP3 player's folders
The manual for the Coby MP828 is available online here: http://assetserver.net/_Assets/Coby/PDF/MP8288GBLU-Manual.pdf .
I hope this helps.
May 08, 2016 | Coby Audio Players & Recorders
Tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 | Computers & Internet
Tip
See file path(s) On OSX 10.5
GO to terminal and type: defaults write com.apple.finder _FXShowPosixPathInTitle -bool YES
This shows the file path of the folder on windows instead of the name.
To revert type in terminal: defaults write com.apple.finder _FXShowPosixPathInTitle -bool NO
on Dec 21, 2009 | Computers & Internet
How do I transfer movies, from a usb stick onto my Apple Mac laptop, then back to another usb stick
1. Plug in first usb stick
2. Open finder and locate the usb stick and the movies within
3. Drag and drop the movies on to the desktop
4. Plug in the second usb stick
5. Open it in finder
6. Drag and drop the files from your desktop to the usb stick
Feb 06, 2016 | Apple Computers & Internet
I have the 8 disc set (mac version) purchased in the year 2000 working with OSX 9. Now I have a new mac with snow leopard version OSX 10. I would like to use the disc's with the new computer, what do I do?
Unfortunately the software will not work with OSX. OS9 (also refered to as classic os) had some compatibility with macs up to 2005 when Apple changed the processors in macs to Intel. Since then all OS9 software no longer works.
There is a small chance you may be able to browse/search the CD's folders for images as the photo objects may be in jpg/gif/png format. Try opening finder, select the CD. and search with the text box in the upper right corner in Finder.
Feb 10, 2011 | Hemera Photo-Objects 50000 Volume II Full...
I recently purchased a Verbatim USB 2.0 1-TB storage External Hard Drive. I have a Mac with OSX 10.5.8. I properly connected the hard drive to my computer and an appropriate screen display icon which I...
The NERO software is most-commonly used to write to CD/DVD/BluRay recordable media.
With Mac OS, just "drag-and-drop" your files and folders onto the icon for the drive, to "copy" the files.
Nov 04, 2010 | Verbatim External, USB 2.0, 750GB...
MacBook (10.5.6) saved 3 documents to ''Apple - recent items'' today instead of to my memory stick. I can see them, but neither open them nor send them back to my memory stick. ''Help'' gives a...
You can use finder, but I would try Spotlight. Basically click the magnifying glass in the upper right part of your screen and search the name of the file. It will list all documents and programs that have that name. then open the containing folder and cut and paste to stick. The following is a video describing how to use it. http://www.dummies.com/how-to/content/how-to-search-for-files-and-folders-on-a-mac.html
Jan 12, 2010 | Apple Computers & Internet
I emptied the cruzer 8Gb by deleting the files.
Reformat the drive. Plug it into the Windows computer, and right click on it in the My Computer folder. Select properties, and you can reformat from there.
Oct 29, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Can't Delete Files From Global MP3 Player with Mac OSX
When moving an item to the trash, it actually is just in a hidden ".Trash" folder on that disk, so no space is actually freed up. Can you try hooking the drive back up and then emptying the trash?
Jan 18, 2009 | Global Marketing Partners V3-8B512G (512...
Panasonic RRUS550 (512 MB 1425 Hours) Handheld Digital Voice Recorder Logo
261 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
