Question about Vehicle Parts & Accessories
Vauxhall frontera 1998
When i try and start my 2..5 turbo diesel it wont turn the engine then it starts making a whistle sound
    Problem Solver:
  • 5 Answers
2 possible things.
1 your battery may be low or empty,
2 your starter could be damaged. in that case u\'d need to buy a new one.
good look
Posted on Mar 28, 2014
2 Suggested Answers
SOURCE: DEI GM Immobilizer Bypass: vauxhall frontera 2.0 sports wont start how can i ...
get a fiver worth of petrol tat will sort it
Posted on Oct 02, 2011
My 98 isuzu rodeo wont idle and keeps dying then doesnt want to start.
which engine?
2.3 L 4ZD1 I4
2.4 L C24SE I4 (GM, Aus)
2.4 L C24NE I4 (Euro)
2.6 L 4ZE1 I4
3.1 L LG6 V6 (GM)
3.2 L 6VD1/6VD1W V6
2.5 L 4JA1 diesel I4 (Cameo, TH)
2.8 L 4JB1-T turbo diesel I4
3.0 L 4JH1-T turbo diesel I4
3.1 L 4JG2 turbo diesel I4
Jul 13, 2014 | 1998 Isuzu Rodeo
Whistle from turbo.. 2007 mazda bt50 2.5 diesel turbo. . While accelerating I get this whistle noise in the cab. High pitched sort of. it sounds like its around the passenger side footwell.. if driving...
locate the waste-gate and see if you can cover it temporarily while driving. see if this changes it any. It could have a pin sized hole in the diaphragm. just a guess.
May 04, 2014 | Cars & Trucks
Whistling when accelerating outlander turbo diesel
turbo whistle is common as it comes from the tips of the compressor wheel passing through the sound barrier and the turbulence occurs. IN the older trucks you would the turbo whistle as the engine reached full RPM just before a gear change. In smaller engine it is not do noticeable as there is an excess of air pressure that keeps the compressor wheel at a lower rpm and the pressure is dumped out. Turbo compressors reach revolutions in excess of 120.000 rpm under full load If it has just started to make the noise then check the intercooler system for leaks--loose clamps--- splits - Have the turbo compressor checked for damaged fins from the ingress of fine dirt from a bad air filter---check the air filter is not blocked as the turbo speed may result from running in a partial vacuum ( no load on the compressor wheel)
Jan 07, 2014 | Mitsubishi Cars & Trucks
Where can I find a free workshop manual for a 1993 Vauxhall Frontera
There are none. The manuals are copyrighted and you must purchase them
Oct 20, 2012 | 2003 Ford Ranger Regular Cab
1999 Vauxhall Frontera 2.2 dth ltd. Living in France
take the inter cooler pipe of turbo and try to move the fan or bolt inside the turbo, if you can then theres a problem with the bearing probably oil starvation parts of the fan will have been sucked through the engine so this could cause the smoke problem if the plastic is stuck in the exhaust valve check all oil lines and air lines, try getting some one to hold rag over exhaust pipe and look in engine bay if you can see smoke/exhaust gases coming from turbo unit then theres a leak somewhere,
its a complicated problem and without being there i cant really help anymore than that, sorry jezza
Feb 12, 2010 | 1999 GMC Safari
Whistling noise from turbo unit wv golf mk v
i have a vauxhall vivaro mini bus . since mot turbo started whistling. no smoke no loss of power. vauxhall say a new turbo is needed,£1000, yet me thinks not needed any idears?
Oct 25, 2009 | 2005 Volkswagen Golf
Turbo whistles in my f f350 diesel
It is called turbo "whine". This is normal.
If it has just recently started making an odd sound, I would get it checked out. Especially if it is a 6.0L.
Sep 11, 2009 | Computers & Internet
My car wont start, 1997 vauxhall astra 1.7 turbo diesel
This sounds like a problem in the fuel shut off circuit. When you turn the key on, it energizes the fuel shut off solenoid on the injection pump. When you turn off the key, power is removed and the pump is moved by spring to the fuel off position. Check for power at this terminal when you are having a problem, ( with the key on) If no power then I would check the wiring and connectors from this connection to the Ignition key. I believe it is wired direct. That can be checked at http://www.alldata.com/products/index.jsp
subscribe3 and get a wiring schematic for the car and see if it is wired direct to the ign switch of from a relay, I am sure it is a connection problem if you have no power.
A 1.7 diesel even if turboed, is dead slow in any vehicle let alone a van. Enjoy the fuel economy
good luck
Mar 11, 2009 | 1998 Isuzu Amigo
Oil coming out of exhaust and whistling turbo
it sounds like your turbo has packed in firstly the oil seal in your turbo has failed thats why ur seeing oil from exhaust & the whistling from turbo is the vanes in turbo breaking up so i would advise not to use car until new turbo is fitted & inter cooler pipes and inter cooler itself are checked & cleaned for swarf from turbo you can check turbo by disconnecting turbo pipe &inspecting turbo vanes (fins) to see if broken up or any damage to chamber.
Feb 14, 2009 | 1991 Peugeot 405
Vehicle Parts & Accessories Logo
76 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
