Question about DeLonghi Nespresso EN660 Espresso Machine
The cup size lights on the top are flashing
The lights are alternatively flashing and when i chose a size it starts but then stops without any water output
Cuisinart coffee center, ss-15, lights are flashing on cup sizes, and won't make single cup coffee.what to do?
We have the Cuisinart combination 12 cup coffee maker with a 6,8,10 K-cup maker. Today 8/06/2017 the K-cup started making a strange sound stopped working and all 3 blue lights 6,8,10 where flashing and wouldn't make a cup of coffee. After some looking around it seemed that the top stainless steel water injector was clogged, I took a long toothpick and slowly pushed it in as I spun the toothpick around slowly as to not break the toothpick off inside, the water injector is sharp so the toothpick will fray as you spin it around inside this is why you must go very slowly. I also did the same to the K-cup holder stainless steel spike tube to make sure everything was clear and clean, I then ran 4 full water containers through the K-cup system starting with the 6, than 8 and 10 oz. size. I was finding little black objects in my 20oz drinking cup as I was doing this, not sure what that was but after running the 4 full containers through it they were gone. Now it works fine. I hope this helps anyone with the same machine having the same problem
Feb 13, 2017 | Cuisinart Coffee Makers & Espresso...
Kuerig keeps brewing without pushing button
my kuerig has water come through the k cup when I close the top without pushing brew cup size and if it does let me make a selection it brews 1/4 of cup I have descaled it 4 times locked in the water reservoir cleaned the needles turned it on and off any other suggestions to try would be greatly appreciated thank you
Nov 08, 2013 | Keurig Coffee Makers & Espresso Machines
Small cup, add water, heating lights keep flashing after brew
I had this problem too.
I just pressed the small brew button; it pulled some water from the reservoir and heated it but nothing came out. Then I opened and closed the top cop thing and both the cup sizes were flashing and it worked like normal again.
Oct 16, 2011 | Keurig Elite B40 Coffee Maker
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
Cannot turn off flashing lights on buttons to start espresso
The keypad needs to be programed. Depending on your model there will be a small toggle switch on the right side, just behind the connection of the hot water valve(you will have to remove the top panel). Move the switch to the left, then press the program button at which time all the lights will be lit. Using a measuring cup press a button you want to program until you get the desired amount, then press the stop button(when programed the light will turn off), repeat to program the other 3 buttons. When done program move the toggle switch to the right. If the machine does not hold the program then the flowmeter under the drain tray(silver box with 3 wires on top), is damaged. Either repalce the top or check the impeller in the flowmeter, the magnets might dirty.(Make sure water is turned off before openning the flowmeter.
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Microwave oven flashed and groaned, staining cover of waveguide
I suspect the water content of the frankfurther was your issue. Operating a mwave at full capacity without adequate load to absorb energy would cause something like this to occur. Ultimately the energy had to go somewhere, it chose the weakest point to dissapate. You mention to glasses of water heated up fine? Then no worrie if theres no additional funny noises.
Suggest you lower the power level to around 25% to cook a furter. :o) Or put a mug of water in with it.
Dec 10, 2008 | Microwave Ovens
Keurig lights flashing
Holding down the Auto Off and the both cup sizes worked for me as well. I rcrvcd my answer from Bryan above in the comments section
Nov 30, 2008 | Keurig B100 Coffee Maker
DeLonghi Nespresso EN660 Espresso Machine Logo
41 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
