Question about Boost Mobile Kyocera Hydro Smartphone
How do you get the home screen to rotate. It has rotated before but only for a split second. I like land scape mode and would like to use it at the home screen.
I've tried every thing i can but no luck.
HOW CAN i GET SCREEN TO ROTATE?
1. Go to your desktop on the nextbook.
2. Tap on the screen and hold for 2 seconds, then remove your finger then a list of choices will appear.
3. Choose screen resolution, it's the second last choice, choose it, it will open another page where you will find the box to check that allows the screen to auto rotate and enjoy!
Jan 17, 2015 | Tablets & eReaders
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
Screen will not rotate and the lock is turned off
Hi
... when you say the "lock is turned off" ... do you mean the screen locking after a set amount of time?
Allowing a screen to rotate is driven by the application. The application has to be developed to allow screen rotation. In some cases like the app from SpeedTest (which you can find on the App Store) only functions in "portrait" mode while the home button is on the bottom ... however you rotate the phone ... 90 degrees or 180 degrees, the screen stays fixed.
Hope this helps,
Ron.
Nov 18, 2014 | Apple iPhone Cell Phones
Acer how to setup
You are looking for an option called Rotation or Rotation Lock (varies by Android version and tablet). Once you find it, orient the tablet so it is in landscape mode, then turn off rotation. If you do not have an option on the bar at the top of the tablet (top pull-down you get by sliding down a finger from the top of the screen), then go to Settings, Display, and look for Rotation, Rotation Lock, or Screen Rotation.
Jul 17, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
My zeki tablet wont rotate when you turn it
go to setting>display>rotate screen
check the box(click in box)
it'll activate auto rotate
Jan 29, 2014 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
How do i get the keypad working and how do i disable rotation lock?
I am not 100% sure what you mean by get the key pad working. If the keyboard on your iphone is not working I would try rebooting the iphone. To do that...hold down both the home button and the lock button for about 20-30 seconds. You will see the screen go black and reboot.
To disable the rotation lock, double tap the home button. From there on the "multitasking bar" swipe your finger from left to right to reveal the audio controls. The rotation lock button is on the left of the audio controls....just tap it to toggle the screen rotation lock on and off
May 25, 2012 | iPhone Apps
HOW DO I CHANGE MY MONITOR FROM PORTRAIT TO
press and hold ctrl + alt key + up arrow. your screen should now go back to landscape.
May 05, 2010 | Toshiba Satellite A135-S4527 Notebook
How do you turn your compter to landscape?
right click on the desktop-graphic option -rotation -from there u can turn on to land scape
Jun 03, 2009 | HP iPAQ H5550 Pocket PC
Format error on my nw-505
be sure to format using the MENU mode on the unit and ADVANCE MENU then FORMAT Press and hold the search/menu button for half a second in stop mode. The menu screen is displayed. Rotate the shuttle switch to select "Advanced Menu" > and press the play/stop button to confirm. Rotate the shuttle switch to select "Format" and press the play/stop button to confirm. Rotate the shuttle switch to select "OK" and press the play/stop button to confirm. "Formatting..." blinks and start formatting. When formatting is complete "complete" is displayed.
This is how i get rid of the problem "Format Error".
May 11, 2009 | Audio Players & Recorders
Boost Mobile Kyocera Hydro Smartphone Logo
14 people viewed this question
Top Boost Mobile Cell Phones Experts
John mullen
Lawrence Oravetz
Are you a Boost Mobile Cell Phone Expert? Answer questions, earn points and help others
