Question about Panasonic VIERA TX-L42E5B 42" LED TV 1920x1080, 50 Hz, Freeview HD, HDTV, LED Backlight
Panasonic TX-L42E5B tv sound working but screen is black
My Panasonic TX-L42E5B has sound but screen is black. Somebody suggested the invertor board had gone. Is this the likely reason, how can I tell and is it an easy fix please? Any input gratefully received.
  • 35 Answers
It can also be the YMain board or the back light inverter board or a capacitor or fuse has blown on the power supply board. Which you usually lose sound before you lose both sound and picture. Try to hard reset is for about 4-6 hours by completely unplugging it.
Posted on May 13, 2014
skotkolr
  • 558 Answers
SOURCE: Panasonic Viera
vga board is bad ot the components on it are blown out.
Posted on May 08, 2008
  • 718 Answers
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Posted on Feb 17, 2009
  • 8457 Answers
SOURCE: Panasonic th-42px80u screen is completely green
Ur backlight video board begining to have problem.When it complely green or no video picture the backlight video board it dead.
Posted on Dec 10, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-46PZ85U Plasma TV
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Posted on Jan 27, 2010
SOURCE: Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
Posted on Apr 01, 2011
Panasonic TX-L42E5B blinks 3 times which board is faulty
When an abnormality has occurred to the unit, the protection circuits operate and set the unit to stand by mode. At this
time the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Fault maybe on the A board 3.3V SOS give me your email & i send you the full timing chart.
Apr 04, 2016 | Panasonic VIERA TX-L42E5B 42" LED TV...
My panasonic tx-l47et5b has power green light and screen lights up but no picture or sound please help.
Need to know more,what do you see on the screen?
if the lcd was faulty there would still be sound.
if you have changed the av board have you checked the voltage supply to it? have you checked all the visible electrolytic capacitors on all boards for bulging or leaking?
please let me know how you go..
Len..
Sep 09, 2014 | Panasonic VIERA TX-L47ET5B 47" 3D LED TV...
How to connect remote control to panasonic hdc mdh1 "?"
is this a sky remote? or a multi remote?
if its a sky:
http://helpforum.sky.com/t5/Archived-Discussions/Help-remote-code-for-Panasonic-Viera-TX-L42E5B-needed/td-p/361937
Jul 03, 2014 | GE Televison & Video
Panasonic tx p50u30b Black/Blank screen
Might be a resolution issue. Make sure the resolution in windows for that monitor is set to 1920x1080.
Mar 13, 2014 | Microsoft Windows 7 Ultimate 64bit 1 PC...
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
Panasonic TX-34P300X Audio problem
I have facing some problem model Tx-34P300X panasonic Tv UK Model for sound not coming .But Amplifire is Ok. Pre not working.
Jan 17, 2008 | Televison & Video
Panasonic VIERA TX-L42E5B 42" LED TV 1920x1080, 50 Hz, Freeview HD, HDTV, LED Backlight Logo
205 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
