Question about Husqvarna Garden
Clutch spring the spring coming from the clutch seems to be hanging loose when the blades are not engaged ... making a rattle noise .. seems like the arm from the clutch is not going back into place when the blades are turned off .. any ideas?
  • 34 Answers
I am guessing that this is a problem that has just appeared. In which case it sounds like the spring may be worn out. The linkage itself may be worn out also. Check to be sure that nothing is loose, nuts, bolts, you get the idea.
Posted on Mar 26, 2014
Harley troubleshooting
Does the noise happen only when you pull in on the clutch (disengage the clutch), and go away when you let the clutch out (engage the clutch)?
If so, that's the clutch plates rattling until the spring load is reapplied to clamp the up.
Aug 09, 2014 | 2010 Harley Davidson FLHX Street Glide
Blades will not engage
when you actuate the "engage blade" lever, two things may occur,
First, a mechanical action, a spring moves to put tension onto the belt.
Second; at the end of its run, actuate a switch (PTF switch) to engage the clutch that moves the pulleys that consequentially move the blades.
if the tensioner is not moving , check if spring has come lose, undone or broken, (more likely in your case) or check the PTF switch.
any other assistance, contact me, good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Apr 20, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Noise from compressor
loose mounts,? frayed belt? noise sounds like what, (scream or rattle)
clutch engaged or now , look and see? or turn it off. and make sure it is off the clutch free spins, OFF.
if off, and noise still, get a new clutch bearing.
if only noise, with clutch engaged that is pump noise
ever heard of a $5 stethoscope at harbor fright.? get one listen to it.
if only the compressor makes noise its bad, end of life.
sure it makes noise , new. listen 1 one other car, to learn good from bad, takes what 5min?
Dec 31, 2013 | 2002 Honda Odyssey
Can you tighten the belt that engages the blade?
check for a spring loaded idler pulley that keeps tension on the belt out of place.
May 17, 2013 | Toro Garden
2008 Road King Classic, rattle from primary
Chances are either the nut on the compensating sprocket is loose or the primary chain is loose.
Jun 20, 2012 | Harley Davidson FLHRC Road King Classic...
Huskee model 287707 blades wont spin belt not broke or spinning?
check for power and ground at the connector that feeds the clutch this will tell you if its a switch or the clutch itself
May 23, 2012 | Garden
Hear funny rattling noise by tension spring pulley, replaced pulley but there is still noise. could it be my bearings in ac compressor making noise? do the clutch suppose to move by hand?
yes! you should be able to turn the clutch by hand.run the car,open the hood,have someone turn the a/c on.you should see and hear the clutch engage.
I’m happy to help further over the phone at https://www.6ya.com/expert/kenneth_3efc1f8510674f04
May 17, 2011 | 1998 Cadillac DeVille
Engine rattle stopped when clutch failed
Most likely its in the clutch, could have been a spring in the clutch disc come loose or out, or the throut bearing went bad, whatever it was they will find out when they replace the clutch.
May 06, 2009 | Hyundai Motor 1995 Accent
Internal engine noise
timing chain loose?  Piston slap?  Rod knock?  Loose clutch spring?
Mar 22, 2009 | 2006 Honda VTX 1300 S
Garden Logo
192 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
