Question about Water Heaters
Boiler fires up for five seconds then shuts down then fires up for five seconds continually
Hi when the boiler comes on in the morning all is fine until i turn on the hot tap. i then get constant hot water. when the hot tap is turn off it should then go back to heating.but then it keeps turning its self on and off every 5 seconds this is also the case for the hot water. if boiler is turn down and left to cool down it will work fine again until i call for hot water again. this happens both ways. i.e if i turn on water first all is fine until i turn on the heating
  • 104 Answers
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
mixing valve must be replaced
Posted on Nov 02, 2008
  • 3 Answers
SOURCE: combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Posted on Dec 30, 2008
  • 150 Answers
SOURCE: alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Posted on Sep 02, 2009
mrhotandcold
  • 248 Answers
SOURCE: Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Posted on Oct 12, 2009
mrhotandcold
  • 248 Answers
SOURCE: Combi boiler will not fire up for hot water or heating.
check tops of spindles at radiator valves for leaks easy repaired set pressure to .8bar setting at 1.5 may be make overpressure and blow off through high/pressure releasese valve
Posted on Dec 03, 2009
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
Burner not quite right
You need to get an engineer urgently , there could be a flue problem , i would suggest shutting the boiler off until then
Jan 23, 2014 | Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
Halstead boiler reluctant to stay on
next time it turns off let it cool and clean with a cotton swab with rubbing alcohol after brushing.
Aug 31, 2009 | Water Heaters
I have Crown Tobago boiler that cut off two days ago
Possibly due to a power failure, control unit needs to be reset. Hit reset button. Hold for 30 seconds. Also no fire typically due to nozzle clogged, no fuel which means control will shut down. Water in fuel will also shut boiler down. Clogged filter will decrease fuel flow. Electric eye face is dirty which will also shut it down. If you have a two line system, open up bleeder and see if you get a good flow. Check electrodes for burned ends or out of gap specs.
Aug 04, 2009 | Water Heaters
Modena 80e starts up itself
doe's your blr have pre heat option if so it would be normal for it to fire up then go off
Jul 29, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Water Heaters Logo
73 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
