Question about Sunny Health & Fitness Crazy Fit Massager
Crazy fit body sculpter
The machine makes a ticking noise when iam using it
98 ford escort ticking never loses power nor sluggish.pulled each each sparkplug ticking never stopped.what could it be
You mention a "ticking" sound,,is this from the top or bottom of engine..?
Does the ticking go on acceleration or increase with engine speed..?
A ticking noise from the top usually indicates camshaft/valve noise..
Run your engine until at normal temperature, then turn off and leave for 5 minutes for oil to settle..
Make sure your car is on level ground and check your oil level..wipe dipstick and check it again, make sure you push the dipstick all the way in an re check oil level. Top up if necessary.
The best thing to do is remove old oil filter. Drop the old oil and fit a new filter, top up with new oil, run the car and check oil level again, top up if necessary.
Low oil and old oil can wear thin and cause ticking noise from top of engine, and will also NOT PROTECT your engine...oil is the blood of your car, check levels weekly at most and change every 12 months or as recommended by your car booklet.. Use the BEST oil you can afford.
Nov 29, 2016 | Ford Cars & Trucks
Power slimmer bm1505 instruction booklet
hi..
my sister has given me her body sculpter power slim bm1505... but i have discovered there is no remote or cable ( lost when she moved).. i am enquiring to see if i can purchase the cable and remote from a retailer and how much it would cost..
if you can help i would be a very soon to be slimmer lady ha..
thanks in advance
jess
Feb 04, 2014 | Horizon Fitness Treadmill Running Machine...
Drum makes a lot of noise when turning worst on spin
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Thank You for using fixya
Sep 06, 2011 | AEG Washing Machines
Player still searching & making ticking noise.
you will need to clean the lens whith alcohol and a soft cloth.
Mar 28, 2010 | Polaroid PDM-1040 Portable DVD Player
My turn signal keeps making the ticking noise after its cancelled
That is the "Hazard Switch" located on the dash. A very easy fix and have always been a common issue with those types of GM cars.
Oct 06, 2009 | 2000 Oldsmobile Alero
Ticking getting worse!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
edgfd
Sep 30, 2009 | Bosch Nexxt 500 Dryer
2000 Ford focus PO123,PO1120
clunking from the tranny has nothing to do with the tps or anything even close to it. you may end up needing a new transmission. my friend has the same car as you and apparently they are notorious for having terrible transmissions.
do a vaccuum test to diagnose the revving properly
Sep 05, 2008 | 2000 Ford Focus
Ticking noise
this is the motherboard part number 2252189 it is getting ready to go out but before you replace motherboard make sure the unit is grounded a bad ground can also make the same problem happen
check ground at wall and all green wires on or around compressor and door hinges
Dec 06, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Sunny Health & Fitness Crazy Fit Massager Logo
32 people viewed this question
Top Sunny Health & Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Sunny Health & Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
