Question about Dishwashers
Bosch dishwasher contiuned to flood all night...
My dishwasher flooded, however it continiued to pupmp water all night causing my kitchen to look like a swiming pool. What would cause this?
  • 957 Answers
It sounds like the float is stuck. Look for a round disk on bottom of dishwasher ( inside) Push it down and lift it up to make sure it is traveling without getting stuck. It is suppose to rise and then cut off water.
Posted on Mar 26, 2014
Cerfer39
  • 709 Answers
SOURCE: Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Posted on Oct 23, 2007
  • 1003 Answers
SOURCE: Indesit D43 Dishwasher
REPACE FLOAT SWITCH
Posted on Jan 18, 2008
rickzilla
  • 706 Answers
SOURCE: Kenmore Ultra Wash III Dishwasher will not drain properly
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Posted on Aug 26, 2008
SOURCE: Reset anti flood device in dishwasher Beko DWD 4310 S
**** the water out of the pan below the dishwasher, there is a float in the pan if you have a leak and the pan fills with water
Posted on Jan 17, 2009
vickygomar
  • 460 Answers
SOURCE: dishwasher flooded
These 2 things that may happen
1.- the cycle was interrumped
to find out if this was the problem let the dishwasher go full cycle with out opening.
If this won't solve the problem let do a cleaning because
sound like is plug.
http://www.youtube.com/watch?v=nr6tIO5iNSc
Wasth this helpful?
Posted on May 15, 2009
Bosch model SHX68T55UC/02 Completely dead after 2 inch flood in kitchen.
You will need to remove the unit from its installation in the cabinetry. Check the wiring connector located on the rear of the base, near one side. The wire connection must be clean, dry and securely snapped into place. If this connection is burned, distorted or won't allow the plug (special shape) to click securely into place then it should be replaced. Since the unit is totally dead it would appear there is no power reaching the control module, But, you can also confirm that water did not overflow the top of the dishwasher base pan and allow water to enter the pump motors (there are two.) If so these must be thoroughly dried. They may be damaged if power was supplied to a motor with water in the winding and contacts.
Oct 03, 2016 | Bosch Dishwashers
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Contunuous draining turned into a flood when unit powered off
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
May 09, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher = machine on but no water, so the lower basin has water in it and because of it the FLOOD CONTROL SWITCH IS ON, so how do I drain the rest of the water so the FLOOD CONTROL SWITCH goes...
If you can see the water use a shop vac if not you will have to pull the unit out and remove the left side panel after removeing the water you will need to find the leak that caused the bottom to fill with water
Mar 29, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch slimline dishwasher flooded kitchen
Your debris filter needs to be cleaned. It is found under the dry bar in the bottom of the tub. It looks like a plastic mesh and you can usually remove it to wash it out if not use an old toothbrush etc... this should help.
Jan 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU43C Dishwasher
Is there no water coming in( hear no water at all) or no water NOT staying in ( drain motor running) ... the float switch is a safety to keep the dishwasher from flooding ...turns on the drain motor as soon as the door is closed..
I could check the control and see if you have power to the water valve.. maybe a control problem if no power..
Sep 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
