Question about Hardware & Accessories
Need manual for a Grassun DiGi 42/2-L timer - Hardware & Accessories
2 Suggested Answers
SOURCE: NEED MANUAL
You can find the manual here
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c.ashx
Posted on Jul 16, 2009
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
Need to know why the grasslin Fm/1 Digi 20-L timer won't let me program it. I push reprogram button And it went back to just blinking the days of the week on top but won't respond to anything I push
Likely solution: Current time of day was set without holding down the timer (or clock symbol) key.
Other possibilities: Maybe the back-up battery is depleted and you need to connect timer terminals to correct power source ... these models vary 24V, 120V, 208-240V... look for markings on timer
More possibilities: Troubleshoot following link: This is older version timer.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#module
Manuals on following link:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TRAX
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 11, 2015 | Hardware & Accessories
Want operating manual for a grassun v86/2 digi32 m6 timer
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Talento-400
2) Add comment Feb 2013 and say if product matches your 2-channel timer
Feb 04, 2013 | Hardware & Accessories
Where is the on switch, for constant hot water located?
Question posted under Taco digi timer control
http://waterheatertimer.org/images/Digi-dial-image.jpg
http://waterheatertimer.org/images/Taco-265-3-timer-600.jpg
Taco must have stock of old digi timers because that timer is discontinued.
It's a good timer. It's just been replaced by less attractive, more complicated digital timer with fewer buttons.
The manual switch for this timer is located at top and is denoted by 'hand' symbol.
Press left side for ON and right side for OFF.
Aug 23, 2011 | Taco 265-3 Digital 7 Day Programmable...
My Grasslin Digi 20E-120 timer will not set time or timer. The 1-7 numbers blink. What does this mean?
Digi 20E-120 is 16Amp 120Volt flush mount digital timer with 20 or 140 programs per week.
Grasslin Digi (digi tal/ digital) can be reset using reset button.
Reset might restore functionality, but will delete all programming.
Check that circuit is delivering 120Volt and that circuit is clean without interference.
Also check electrical terminals fit tight on the timer.
Use needle nose pliers and pull terminals off and then push back.
The digi series has 5-day program back-up capacitor so programs should remain, but capacitors go bad.
Power surge can blow out timers. Use surge protection on all circuits.
There are a many Digi timers from years of manufacture by GE and now Intermatic, since Intermatic bought Grasslin from GE.
The digi can be replaced with simple-to--program FM1D digital timer.
Replacement crossover is FM1D20E-120
Open following link for FM1D manual and Digi manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 18, 2011 | Water Heaters
Instrucciones del temporizador GRASSUN
Instrucciones del temporizador GRASSUN:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Jan 09, 2011 | Hardware & Accessories
Replacement timer motor needed
If you have Intermatic timer, then clock motors are available for most hard-wire box-type timers. Most pool and spa timer modules are available or have same/similar replacements. If you have plug-in timer, including power pack or portable outdoor timer or indoor plug-in or in-wall timer, then no clock motors are available.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
If you have Tork timer, then clock motor is available for 1100 series.
http://waterheatertimer.org/Tork-timers-and-manuals.html
If you have Paragon timer, clock motors will be hard to find
http://waterheatertimer.org/Paragon-timers-and-manuals.html
If you have other brands of timer, then clock motors are not available except Deihl, DIGI and Grasslin timer modules, but post brand and model number of timer so I can search my files.
Sep 11, 2010 | Intermatic WH40 - Water Heater Time Switch...
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Hardware & Accessories Logo
1,194 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
