Question about Breville VKJ687 Polished Stainless Steel Jug Kettle
Breville kettle lid sticks
The lid does not always open without manual assistance. Is it feasible to unscrew the lid from the inside and clean the spring mechanism?
  • 274 Answers
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
Posted on Sep 11, 2007
SOURCE: Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
Posted on Sep 15, 2008
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Posted on May 09, 2010
wilderbeest
  • 40 Answers
SOURCE: How do you clean a
Put a cup of vinegar and a cup of water into the kettle and boil. Clean with a brush, rinse, boil once with clean water.
Posted on Aug 05, 2010
SOURCE: how do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
Posted on Sep 16, 2010
Where can I find a replacement filter spout?
About 683,000 results (0.79 seconds) Search Results
    Buy Kettle Spare Parts ' Calcium filters, Lids and More ...
    www.espares.co.uk/browse/at1102/kettles/small-appliances
    Buy spares for your kettle; kettle filters, kettle lids, kettle descalers and more. We carry parts for all home and garden appliances. ... Find Kettle Spares. Black & Decker. Bosch. Braun. Breville. Brita ... Kettle Spout Filter. Genuine spare part for ...
Feb 05, 2016 | Kitchen Appliances - Others
What are the advantages of using clear glass kettle?
Clear glass kettle are attractive, easy to pour from, and refill because of its large top opening. You will find many good functions on the advanced clear glass kettles like Breville and Cusinart. Cleaning the scale deposits from the inside is easy and much more.
Get some more details here: Top 5 Best Electric Kettle
Jul 28, 2015 | Kitchen Appliances - Others
How to descale a breville one cup
NOTE: Not my instructions i just found something similar.
According to the instructions for Breville Hot Cup (presumably similar to yours - the adjustable flow one):
1. Fill it to the max and dispense one cup of water.
2. Add a citric based descaling product into the cup and stir.
3. Tip contents into kettle and close lid.
4. Dispense water from the kettle, discarding the water until it reaches the 'min' mark.
5. Empty remaining water into sink, rinse out with clean water.
6. Fill kettle with fresh water and dispense cups of water until it reaches the 'min' mark. Empty the rest into the sink, then refill ready for use.
Nov 24, 2011 | Breville Coffee Makers & Espresso Machines
How do you clean a Breville JK73 kettle. I have lost the instructios.
Aug 05, 2010 | Breville JK73 Cordless Electric Kettle
Cushion lid release button sticks and the lid does not close
Over time the heat can causes the plastic parts to swell until the button that releases the lid gets stuck. The button can be easily & carefully pried completely out of the hole with a knife **note the orientation of the button and spring for replacement. Clean the button & hole but expect the button to still stick when re-inserted back into the kettle. Take the button back out and if you take a knife and gently carve/scrape away some of the plastic round the inside of the rim of the 'hole' and around the edge of the plastic button, you can remove enough of the plastic so that the button now moves easily back and forth in the hole releasing the lid. Good luck.
Jul 05, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Feb 07, 2009 | Breville Kitchen Appliances - Others
Leaking spout
The spout is electro-welded on to the shell. The most feasible solution is to replace the kettle. If you want to pay the cost for electro-welding, this would not be cost effective.
Just to let you know, electro-welding is not soldering as many people confuse it. The process is very different.
Jerry G.
Oct 01, 2008 | Breville SK85XL Nova Cordless Electric...
Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Apr 21, 2008 | Breville SK500-XL Stainless Steel Cordless...
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Breville VKJ687 Polished Stainless Steel Jug Kettle Logo
49 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
