Question about Aktimate Micro Black Open Box 2-way Active Speaker System with iPod
Not getting power
When I first bought the speakers they worked perfectly fine. After a while they lost power and couldn't function. They randomly turned back on after a few days but once again ended up losing power and since then they haven't worked. I've tried replacing the fuse and still nothing.
TV worked perfectly until recent storm... After storm it no longer has sound
as you present. that maybe speaker wiring or speaker have problem. if no . that"be main board not function good . need to replace as posible. good luck!
Sep 06, 2012 | Vizio 55" XVT3D554SV Razor LED 3D LCD HDTV
How do I fix faulty Jamo D165 Speakers
I just bought a set of jamo d165 speakers and one tweater isn`t working can these be replaced?
Dec 11, 2011 | Audio Players & Recorders
Kenwood KAC-8103D on and off problem
it sounds like the power wire might be grounding out somewhere that you dont know of it could be by the fuse link so I would say put electrical tape on any exposed wire on the fuse link first if that don't work try change the power wire.
Jul 19, 2010 | Kenwood KAC-8101D Car Audio Amplifier
Speaker buzzing at random
It sounds like the socket on your computer is becoming worn or has a loose solder joint.
If you feel comfortable with a fine tipped soldering iron and stripping your computer down I would take a look there first.
Also check the power supply for the speakers to make sure it is not getting too hot.
Sep 09, 2009 | Logitech Z-2300 Computer Speakers
Subwoofer Help
check the amp. the "switches" gain,bass boost...etc they might be over powering your subs and heating them up. if those are fine then you mite want to try your subs on another amp...it migt just be that the subs are easily over heating.
Aug 26, 2009 | Rockford Fosgate Car Audio & Video
Speakers cut out randomly
The only thing i can think of is the amount of power surging into the speakers is too great and they are cutting of to avoid blowing out. I have a similar issue with my surround sound if i turn it up too loud.
Jun 25, 2009 | Logitech Pure-Fi Elite High Performance...
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
Problem with my MX Gt 88!!
use the speakers it came with it works fine for me i have mine hooked up to a 300w inverter anything less i dont get the best sound you cant turn the volume up too loud on the reciever it will draw too much power and shut it off or blow the fuse in you car unless the inverter you are using has an external fuse on it my inverter warns me that i am drawing to much power so when i hear the beep i turn it down a notch and works fine but ya try using the speakers th system came with
Nov 02, 2007 | JVC MX-GT88 CD Shelf System
Need replacement car power cord for NVX226 GPS
I bought a car charger for a motorola razr for ten bucks at a gas station and it works perfectly. i also bought a replacement cord from radio shack which also worked perfectly but hit me for 24 bucks. Either or is fine!
Oct 22, 2007 | Audiovox NVX226 GPS Receiver
Aktimate Micro Black Open Box 2-way Active Speaker System with iPod Logo
20 people viewed this question
Top Aktimate Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aktimate Audio Player and Recorder Expert? Answer questions, earn points and help others
