Question about Sharp LC46SB54U 46 in. LCD TV
The TV does not let you program digital air channels? That option on the menu is not an active option.
  • Devon Sacco
    Devon Sacco May 11, 2010
    What is the model number of your TV?
It is a new LC-46SB54U. It was receiving analog signal until Friday. I am not sure why it will not pick up digital channels and I know we have a good antenna that is powered.
Posted on Jun 15, 2009
I want to hook up my old 1992 Sylvania TV to HD Antenna, but I cannot figure out how to scan or auto-program the channels. Model SRC1351 101
Hello... Somewhere in the same menu as the Air/Cable setting should be an option to scan for channels. It might be called Auto-Program, or something similar. The bad news is that: "On June 12, 2009, the Federal Communications Commission (FCC) mandated that all U.S. based television signals must be transmitted digitally." Since your TV was manufactured in 1992, it isn't capable of detecting or displaying digital channels. If you're really fond of the TV, you will need some sort of conversion box. If you can afford to, I'd recommend buying a new TV, and get the extended warranty. I hope this helps!
Nov 26, 2017 | Sylvania Televison & Video
How can I set a tv to antenna mode in order to receive digital channels?
It depends on the TV. First make sure that the active Input is TV. On some TVs, you may need the original remote or an universal remote that has an Input or Source button (and a code that enables that function for your TV). Some TVs have the Input or Source button on the TV as well or a Menu option to change inputs.
Next enter the On-screen Menu and find a Channel or TV setting option. In that sub-menu, you will find a Source option. (It may give the choices of Air or Cable.) After you set that to the Air, you'll need to scan for channels.
Please add a comment with the model of your TV for additional assistance. I hope this generic comment helps.
Mar 10, 2015 | Televison & Video
GV42L vizio tuner
Your vizio has an internal digital tuner. When you are on air, make sure that it is set up for digital. It might say DTV. Some sets have an analog only and digital only program option in the user menu, or as a seperate input. When in doubt, check your user manual.
May 02, 2012 | Vizio GV42L 42 in. LCD Television
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
How do I tune my hitachi tv. I got it as second hand.
Make sure the cable is plugged into it, or if you're using antenna, make sure the antenna is plugged in. Go to your T.V. menu and there should be an option for channels or programming. After you get into one of those you should have the option to program channels from cable or antenna/air. Also, depending on what model it is and if you're not using digital cable or satellite, then you may need a digital converter box. If you have the model number I can tell you if you need a digital tuner.
May 03, 2011 | Televison & Video
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Cant program tv for digital
Flat panels wall tv's are digital. Go to menu, set to AIR (do not set to CATV)
Then find the "autoprogram" option and select it. It will scan all available channels
Aug 17, 2009 | Televison & Video
My Sharp LC46sb54u does not let you program digital channels from the antenna. The option is deleted on the setup menu. How do you get the digital option back? The manual says once you program channels for...
Go to page 19. Make sure antenna setting is on DIGITAL
Then go to page 11. Change AIR/CABLE option to cable.
Then run the "Analog & Digital Search Start". The digital option should come back.
Jun 16, 2009 | Sharp LC46SB54U 46 in. LCD TV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Sharp LC46SB54U 46 in. LCD TV Logo
287 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
