Question about Roadian HT SUV Tire 265/70R16
What pressure do I fill
How much tyre pressure do infill
    Sergeant:
  • 192 Answers
Open your driver door, there is usually a sticker that will tell you how much air pressure to put in the tires, if you can't find the sticker, look in your manual. Normally 30 psi unless you have a large cargo van. Worst case call a dealer and ask them.
https://gmdautoperformance.wordpress.com/tag/tire-pressure/ tire pressure GMD Auto Performance
Posted on Feb 22, 2015
    Master:
  • 710 Answers
Per the vehicle specifications.
Posted on Sep 01, 2014
Hi I have got a mercedes e250 coupe they have 19 low profile tyres, can you tell the correct tyre pressure please cheers Michael.
read the tires sidewall for max pressure. fill to almost that. rub chalk across the tire outer surface. drive in a straight line 100 feet. if the chalk is worn off the center let some air out and do it again. when the chalk rubs off completely you have arrived at the correct pressure. this works for any tire
Oct 09, 2017 | Cars & Trucks
What are the tyre pressures for a peugeot 208
the tires have that stamped into the side walls . and should also be on the tag on the door frame .
Nov 18, 2016 | Peugeot Cars & Trucks
How much air pressure in tyres 245 35zr 20
Lok inside your drivers side door jam or owners manual for proper PSI for your specific vehicle. If just filling tire just to fill it, look on the sidewall for proper PSI range.
Apr 16, 2016 | Cars & Trucks
How to inflate pneumatic tires?
You will probably find that they are infil tyres which are classed as solid, so they can not be inflated, your problem will lie elsewhere,ie :- something rubbing against the tyres.
Apr 03, 2014 | Pride Health & Beauty
HEAT BUILD UP ON REAR TYRE OF MY 2013 ELECTRA GLIDE
tyres get hot from working on a hot road surface so if properly inflated the tyre temperature will be around 10 degrees hotter than the road surface . To get noticeable hotter means they are under inflated and the side walls are flexing excessively or they are overloaded which causes the side walls to flex excessively as well. If you are concerned and the tyre pressure is correct for the weight and speed you are travelling there are places that will inflate your tyres with nitrogen which reduces the tyre temperature considerably and extend tyre life.. Many heavy haulage trucks run nitrogen filled tyres and extend tyre life by up to 20%
Sep 04, 2013 | Harley Davidson Motorcycles
Tyre Pressures: The Handbook for my April 2002 reg. V70 Estate gives two tyre pressures for both the front and the rear tyres, but I am getting misleading advice about which is the correct one to use. At...
Hello, any pressure in between is fine, these are recommended pressures, i personally look at tyre wear when putting pressure, if its wearing on the outsides it means it has not enough pressure, if it wears in the middle it has too much pressure, as a general guide 32psi is used at most tyre shops, extra 100kg does not make much differance to a 2 ton vehicle, otherwise you would be changing tyre pressure every time you fill up your fuel tank!!!!
Mar 07, 2011 | 2001 Volvo V70
Hi i have a vw lt35 what tyre pressure should i put in back tyres please.
all tires very by make. on the side wall you should be able to read the suggested air pressure. this usually reads as follows (fill to 35 p.s.i. cold) or ( max 44 p.s.i. ) fill the tire to that suggested pressure to avoid premature tire wear. i hope this helps
Jan 08, 2011 | 2005 Volkswagen Microbus
What is the tyre pressure for toyota echo 2003 with 14 size
STANDARD TYRE PRESSURE IS 28LBS(1.8BAR) CONSTANT HIGH SPEED, IS 32LBS(2.1BAR).I SET ALL OF MINE TO 30 ALL ROUND...AND CHECK EVERY TANK FILL OF GAS.
Sep 23, 2010 | 2003 Toyota ECHO
Dodge caliber tyre pressure light keeps flashing but tyre pressure ok
probally falty or dirty sensor in wheel... try bleeding off air pressure in all 4 tires and re fill them
Feb 27, 2010 | 2007 Dodge Caliber SXT Sport Hatchback
Can ne1 tell me the tyre pressure for a honda cbr fv 1997
check on the sidewall, should be like 42 psi max. have local tire store fill them up and ask what pressure they put. it will probably be manufacturers suggested pressure.
May 23, 2009 | 1997 Honda CBR 600 F(3)V
Roadian HT SUV Tire 265/70R16 Logo
62 people viewed this question
Top Nexen Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Nexen Vehicle Part and Accessory Expert? Answer questions, earn points and help others
