Question about Dell H275P01 275Watt Power Supply
Power supply burned - Dell H275P01 275Watt Power Supply
    Problem Solver:
  • 16 Answers
Burnt means not working.
U have to check first the components and replace them.
Then i will say whats up next
Posted on Aug 26, 2014
Emachine T2240 computer, powers on no signal on monitor. Power goes on, but no video?
When power supply got burned on the computer. A problem arises first in the CPU. If the power supply burned because of a power glits is a different story. try to save your data you probably need to buy a new computer.
Nov 04, 2015 | E-Machines eMachines Desktop PC
I have 6 gp328 and my multi charger power supply burned i guess due to the variying of frequency, can i use diffrent power supply with the same output voltage of the burned power supply?
yes you can. So long as voltage is the same. Replacement power supply runs about $120.00. Also make sure replacement power supply has the same current capabilities as original
Apr 15, 2012 | Motorola Mag One BPR40 Two Way Radio
We had a power outage - the computer was on a circuit breaker outlet. The other computer came back on, but the one with the siverstone power supply will not start up
Hmmm, First of all check the fuses if any that may have burned out due to the power outage. If this doesnt help. Open up the power supply and smell it for any burned out parts. If you can smell the scent of burned electrical parts then you should replace the power supply. It should solve your problem. Also check the motherboard for any anomalies.
May 19, 2010 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
Hp 763n, the computer crashed and I got a bad burning small for the 200w power supply. Do you think any other damage was done or I could just replace the power supply?
Hello
Usually The motherboard and other components are protected by the power supply first.
So no i doubt you have any other damage.You need to consider what caused the power supply to burn up.Maybe you need a bigger one.
Have a good day.
Apr 29, 2010 | Computers & Internet
Monitor shuts off.. but light stays green..
common problem. the lamps burn out. the invertor that powers them burn out and the power supplies burn up., you can usaaly repair the power supply with new capacitors
Jan 03, 2010 | HP w1907 LCD Monitor
Power supply not working
Hello my friend, if one of your power supply's part is burned, your power supply won't work else if its work i has a short time to operate and it will be burned the whole board of your supply. Mainly the reason of burning your supply are the following: 1. The Electric supply  from the source is to high or above the limitation of your Power supply. 2. Your power supply is over capacity. 3. You're power supply board develop a liquid moisture inside that is why it shorted and eventually the board is burned.  4. The load of your power supply is overload due to some device you attach that is beyond to the limit of your power supply's wattage capacity.
Note: try to see the wattage or voltage or the capacity of your power supply can supply the electricity within your computer system. To ensure that it does not exceed the limit of your power supply's limitation.  I therefore reccomend that to avoid burning the entire power supply board from short circuit, it is recommended to replace your power supply to avoid incidents may arise.
Hope this advice helps your problem. If you need more assistance just reply to this post.  If this solution or recommendation is able to solve or help your problem then please rate it.  Thanks
Jun 25, 2009 | Office Equipment & Supplies
Power supply burned
These power supplies are not longer being manufactured and very hard to find. The defective power supply can be repair.
If you need further assistance, write to jah2mil@hotmail.com
May 28, 2009 | Astar LTV-3001 TV
My dvd burner won't burn - format only +. It's a _NEC DVD_RWND-3520AW I had this problem before and I was given the link of some firmware but I have updated now again (as I reformatted computer since the...
Ru using any softwares to burn DVD disk.( like nero )... if the operating is XP you need some software to burn the DVD disk,,,,where as VISTA OS has DVD native burning ,, where u can burn DVD with out any third party software. think this helps u.......TC bye.
May 14, 2009 | Falcon 4620 Accessories: POWER...
I plugged the printer into 220 volts inlet ,burned power supply
Cheaper to replace the machine than buy a power supply - unless you find a parts machine somewhere.
Mar 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Power supply burned up
yes because the spare parts are not compitible and as it is burned if you opened it, warranty will void please give it as the condition
Oct 27, 2008 | StarTech.com (ATXPOWER250) 250-Watt Power...
Dell H275P01 275Watt Power Supply Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
