Question about Fujitsu LifeBook AH532 Notebook
Keyboard not woarking
Number keys on left side not working
Left side of keyboard 123456789 is not working
Do you mean the right side of the keyboard is typing numbers instead of letters?
If so, you have enabled the NumLk which turns the RHS of the keyboard into the number pad.
Press the NumLk key near F11, F12 function key and the NumLk LED will switch off and return your RH keys back to letters.
Jun 15, 2012 | Toshiba Satellite L500 Series Notebook
Number key not working on laptop
If you are talking about the number symbols that are on keys U,I,O,P,J,K,L,M then notice what color the number symbols are on those keys. Normally they are blue or might have a square around them. That means you have to press and hold the key that is the same color or has the square around it on the left side of the keyboard. Normally you would Press and Hold the FN function key at the lower left hand portion of the keyboard, then hit the key for the number you want. Notice that the FN function key will be the same color as the numbers. If it's not the FN function key then it will be the key that has the square around it like the numbers has.
May 23, 2012 | HEWLETT-PACKARD Pavillion DM1-3020US...
Half of my letter keys when i type are numbers???????
You have number lock on "num lock" fine that key on youre keyboard (ussualy top right) and press it. If its colored then press it with function key "fn" left down side of keyboard.
May 02, 2010 | Advent Netbook
Right side of keyboard does not work
check to see if your number lock is on. it is located on the top left corner over the number pad
Apr 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
Keypad on right side doesn't work
Try pressing your numlock (top left of the keypad) and try the numbers again. Try your keyboard in another computer -- if they still dont work, you have a hardware failure ... time for another keyboard. If it works on another computer, then I would recommend right-clicking on "My Computer" and selecting "Manage". Go into the hardware manager, and delete your keyboard, and reboot. The Windows will find your keyboard and reinstall the drivers, hopefully resetting whatever configuration was previously blocking your keypad keys.
Apr 10, 2010 | Apple M9034LL/A Keyboard
Were is the enterkey as on this keyboard it is not shown
on the right hand side of the main keyboard (not on the number pad side).
idicated by an arrow pointing to the left (above the shift key and below the backspace key)
Mar 25, 2010 | Compaq Keyboard
Can't switch ports using PC keyboard
Make sure that your keyboard is connected to the keyboard port of the switch. The USB ports on the switch has pictures that indicates where the keyboard and mouse should be connected.
The hotkey combination is CTRL + ALT + SHIFT + Port no.(1,2,3 or 4) + ENTER
Note: "tap the keys one at a time and not at the same time"
Jun 17, 2009 | IOGear USB gcs1734 4-port KVM Switch
Some keys are not working in my keyboard what should i do
If its a multi-media keyboard and the its the muti-media keys that are not working, there may have been a disk to install the keyboard drivers for those keys. Install the disk that came with the computer, or go to the manufacturer's website and see if there are drivers you can download and install.
If its just random keys, try the keyboard in another computer and see if the same problem occurs. If so, return it to the store for another one if you are within the return policy days. If not, just buy a new keyboard.
Apr 12, 2009 | Lenovo Keyboard
Keyboard not working
Hi Simran Hope you are doing good. Please try the following solution. Press Fn (Function button) on the left bottom side of your keyboard that is between the left Alt and thw windows key and while holding it down press the Num Lk key on the top right side of your keyboard. It is between the Prnt Scrn and Pause button. Please chcek your keyboard and advise if it works fine now or not.
Jun 14, 2007 | Dell D520 Notebook
Fujitsu LifeBook AH532 Notebook Logo
42 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
