Car Audio & Video Logo
A
Anonymous Posted on Mar 25, 2014
Rubicon 1002 overheating
Overheating at high volumes, what can be the problem
2004 Jeep rubicon is overheating. Head gasket has been replaced. Radiatior hose is not pressurizing. Fan is spinning, thermostat has been replaced.
I have seen the water pump impeller go bad on a lot of jeep engines. Take off the top radiator hose and run the car. Run it long enough to have the thermostat open. Have a garden hose in the radiator inlet. See how much water flows through the hose.
Put my new"used" Jeep Rubicon into 4 wheel drive, high and low, and when?
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
How do I reset after overheating
It's getting to hot.
Needs a cooling fan.
Too many speakers or too high a volume.
Let it cool. Should restart.
If you unplug it,you will lose your presets.
I have a Behringer 1002 mixer. Applying 0 dBu unbalanced to the input I need the -10/+4 control in its most sensitive position to acheive 0 db out with the main output control set at 0 dB. Is this cor
Depends on the input you are using. First you need to calibrate signal coming in with the Gain attenuation knob. Setting this prior to adjusting your channel output volume should calibrate the signal so when the channel volume knob is set to 0 and the Main volume is set to 0, the meters should indicate a true 0 reading.Not setting the Gain correctly will affect this. On the 1/4" channel inputs, you have less adjustment and may have to adjust the item you are plugging in from its source. If you are having issues with high gain, chances are it could be a cable issue, or something from the source itself.
Whow i connect my xenyx 1002 mixer to audiophil 2496 sound card
You must connect:
the main out of the 1002, or the ctrl room out of the 1002 at your power amplifier's input.
the line in 9/10 of the 1002 at your 2496's line out.
the cd/tape out of the 1002 at your 2496's line in.
in case of a cd connect it's line out at line in 3/4, or line in 7/8 of 1002
some mic at the mic 1 or mic 2 of 1002.
That's the way you're going to have control for:
the mic level from channel 1 or 2.
cd level from channel 3/4 or 7/8.
pc playback from channel 9/10.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Power to rubicon 404 no sound 4 channels of 2-way high pass
Check RCA,s at the back of the head deck, make sure sub is set to low bass frequency, make sure gain is turned up on the amp and head deck has subwoofer enabled and bass on. If you are powering speakers make sure the balance on the head deck is set to 0. Make sure it's wired up properly.
2answers
Hi there .......my sa gx303P stereo amplifier/tuner technics ...the cooling fan for the power amplifier works only on a somewhat strong signal .....if you play soft music at low volume the cooling fan...
These units are designed to only run the fan when necessary. If the unit is overheating, there is a problem in the detection circuit. This is a relatively inexpensive repair. If you are getting overheating when running at a low volume, it suggests that the speakers are not matched to the amp. In other words, the amp is expecting an 8 ohm load and is being presented a lower ohm load. This makes the amp work harder and generates more heat. Check the speaker wires and make sure that they are not frayed or crossing in any manner. Also, verify that the rating of the speakers is correct.
Update this with what you find.
Thanks,
Dan
Tv remote
Advent ADR-560 codes for a Sony TV are:
1002, 1218
1helpful
Kicker ZX300.1 shuts off after long play at high volume
It's probably overheating and the thermal protection circuit is shutting the amp down.
If it has a fan, the fan may be defective. If I'm not mistaken, the fan only runs at high temperatures so if you check it, you need to do so when the bottom of the amp is almost too hot to touch.
If the fan is working properly, you may be driving too low of an ohm load.
If it's neither of those, get the amp up off of the mounting surface and use an external fan to move air across the bottom surface of the amp.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
