Question about Canon LASER SHOT LBP 3360 Printer
The printer will only use manuel feeder lbp3360
The printer will only use the manuel feeder
Is the Canon lbp3360 laser printer wireless capable?
This model printer does not have wireless capability, BUT it has a network card that allows it to be connected to a LAN.
Network ready
Users can share the printer across a network with the built-in Network Interface Card. NetSpot Device Installer ensures quick and simple set up.
Jun 30, 2011 | Canon LASER SHOT LBP 3360 Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
HP Laserjet 4200 with optional Envelope Feeder will not automatically pull #10 envelopes from Envelope Feeder?
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
Feb 08, 2011 | HP LaserJet 4200 Printer
I have a Brother printer and everytime I try to print something the paper gets jammed. How can I fix this?
take the tray out and look at the bottom where the paper goes in maybe its dirty or there is a paper stuck or the roller doean not move
i dont know what model you have but if you have manuel feed try it and see if the printer is ok so you know that its only the tray feeder
Aug 24, 2010 | Brother Office Equipment & Supplies
Hi I cannot get my Canon printer Lbp3360 to print & have lost the manual, How do I get another manual?
Click this link (click here), open it and select the Operating System, i.e. Windows xp or Windows vista or windows 7 or Linux etc.. etc.. and then Language, click Submit, the available softwares and drivers for the specific operating system will he displayed, click the link available to download the software/driver.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | Canon Office Equipment & Supplies
I am having problems with the paper feed jamming. I can't find a soluntion in the manuel or the prompts. The left side (facing printer) sends the paper in a an angle,
Hi, sometimes what happens is that there could be objects blocking the path of the paper on one side. Maybe a paper clip or a pen, I have seen this many many times. Just turn off the printer and remove the paper from the feeder. Unplug the printer from the power cord. Then flip the printer upside down and shake it a little most of the times you will find something stuck in there and it will fell down. If you do not find anything maybe then there is something wrong with the feeder roller. Also try the following link http://bit.ly/9nrlMW
Feb 01, 2010 | Lexmark X2500 All-In-One Printer
Phaser 7300 jamming manual feed
Can you print fine with no jams from the lower tray?
make sure you have clean new paper and start out with the 11"x8.5' letter paper. If you have that then follow the instructions below.
  1. Make sure there is no peaces of paper jammed in the path.
  2. clean the rollers with regular rubbing alcohol sometimes the rollers get way dirty to pick up the paper.
  3. If none of these tricks helped you then you have to change the the manuel feeder. part # 116-1561-00 good luck.
Dec 07, 2009 | Xerox Phaser 7300DN Laser Printer
I have a WorkCenter M20 and I am unable to use the document loader on the top of the machine... why is this? I try to load the documents and press start, but then onlty a blank sheet is spit out, because...
What you want to do is this. Turn the machine off, then go to the back of the machine and unplug the document feeder, There is a white connector with 2 thumb screws holding it in place. loosen the 2 thumb screws and unplug the plug. With the feeder unplugged turn the machine back on and let it come to ready. Once it comes to ready turn the machine back off, then plug the document feeder back on and turn the machine back on. That should re detect the document feeder and work fine. The M20 for some reason just forgets it has a feeder and you have to force the plug and play portion of the software to detect the machine not having a feeder then seeing that is has one. I don't know why, not even the newest versions of firmware for the machine resolves that issue. Odd,,,,,
Mar 13, 2009 | Xerox WorkCentre M20 Black and White...
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
May 20, 2008 | Brother HL-2040 Laser Printer
Canon LASER SHOT LBP 3360 Printer Logo
old marine
old marine
