Question about Kenmore 22422 Top Load Washer
Washing machine wont stop filling
Yesterday my washing machine flooded the basement floor. It seems to not recognize that it is full and will not start agitating. Just keeps filling and filling. It spins fine when I manually put it there, and empties okay. It just doesnt seem to know when to stop filling and start washing.
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
  • 3,741 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Oct 01, 2009
  • charlymonty Oct 01, 2009
    If your washer doesn't agitate, check these:
    Lid switch
    Motor coupler
    Belts
    Clutch
    Drive motor
    Drive pulleys
    Transmission
    Agitator
    Lid switch
    If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    Motor coupler
    Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
    Belts
    Clutch
    If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    Drive motor
    Drive pulleys
    The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
    Transmission
    The transmission could have either of these problems:
    • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
    • The transmission may have a worn or broken gear, or some other internal problem.
    If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
    Agitator
    The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Had a patio put in and Contractor apparently did NOT hook up or install drainage pipes deep enough into the as my basement has flooded three different times
im not sure that the patio would have much effect on flooding in the basement
hi precipitation this year and a higher than normal water table which is the lvel below ground that if you dig into starts to fill with water.
your problem is more likely a drainage issue are there any sump pumps in your basement or does it at least have a floor drain if so perhaps there is a clog
call a plumber and the patio contractor and have a professional determine the reason for the flooding
ps you can purchase portable sump pumps you can set on a flooded floor and plug in and they will pump out water when the floor floods automatically
Simer 1/4 HP Portable and Submersible Utility Pump (4)
Questions & Answers (15) $8999 /each
Overview This versatile pump is lightweight and easily taken to remove water. Heavy-Duty Aluminum Construction for durability. Pumps up to 1320 Gal. per hour and comes with a male garden hose adapter. Home Improvement Made Easy with New Lower Prices Improve Repair
Feb 09, 2018 | Washing Machines
Water fills when machine is off
I would think perhaps you need to call a repair man to have inlet valves replaced .
Sep 05, 2017 | LG WM2240CW Washer
Washing machine wont stop filling with water even on small load it floods my floor
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Apr 20, 2011 | GE Washing Machines
Wont stop filling up with water
1. if the water is not flooding the floor, then you have a drain hose siphoning problem. raise or loop the drain hose up in the back of the machine higher than the highest water level of the machine.
2. if water is flooding the floor and the only way to stop it is to shut it off at the fawcet then the water valve is bad and needs replacing
Jul 01, 2010 | Whirlpool LSR5232L Top Load Washer
Wont stop filling
if the unit is not flooding the floor pull up the drain hose to the high part of the control panel.make sure to pause or turn the unit off let the water drain out of the hose when it has stopped the restart your machine.
if the unit is flooding then you need to check the pressure switch
Apr 10, 2010 | Washing Machines
F21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Washing Machine Wont Fill and cycles unresponsive, Help :/
Sounds like your control board is shot. Do you have 120VAC going into it?
Oct 30, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
184 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
