Question about Philips Televison & Video
Philips superscreen 41 without remote
I just bought a second hand Philips Superscreen 41 and it didn't come with a remote. I can't get any channels or anything. There's no AV button or anything that I can see but it has an AV port at the back with a switch saying 'input/output'. How can I change it to AV or tune it into channels/set top box without the remote?
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
SOURCE: LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Posted on May 13, 2008
jack_daniels
  • 304 Answers
SOURCE: tuning a philips remote to a philips tv
instructions on tuning a philips universal remote sbc ru 440 to a philips tv
Posted on Nov 23, 2008
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Posted on Jan 15, 2009
SOURCE: finding AV channel without a remote control
get ewf 2004 on av channel without remote
Posted on Feb 19, 2009
How to reset access code on magnavox 20ms233s
Hi. It's really necessary to have the original remote. All so called replacment do not have the "menu" button. In Philips TV's access code is not rquired. In your case, some channels are "whiped" and cannot be recalled. If you can go into setup-menu, things can be rearranged. There are numerous web-shops where you can buy an orignal remote. I recently bought an original remote for my DVD player. This however was at an on-line shop in Belgium. Just surch for Pilips on line shops in your country. Good luck.
Sep 10, 2014 | Philips Magnavox 20MT133S 20" TV
Philips tv problems
you must reset the MENU, and add the channels that your are missing. 2) However you must ask to your company supplier from cables about this problem, ge the support via ONLINE chat with them for fix it.
God bless you
Dec 06, 2013 | Televison & Video
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
Jun 30, 2009 | Philips 20PT6441 20" TV
Not all the buttons are working on the remote
You may have to change your code. http://www.urc.philips.com/ This link will take you to the Philips Support site where you can download manuals and code sheets for your remote.
Mar 15, 2009 | Philips PM435S Remote Control
I have a philips tv that i bought without a remote, and then bought a philips universal remote but am stuck on how to tune the channel with the remote. Very frustrating, cannot locate sticker stating brand...
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Apr 08, 2008 | Televison & Video
Can I use another remote?
I have the same model TV, also without a remote. I found a Philips universal remote model CL019 at Big Lots and it works just fine. However, for some reason when I tried to program in the channels it would only program in up to channel 23, and then after about 15 seconds add channel 60. Can anyone help?
Jan 19, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Philips 55PW9363
Hi! ronogre,
This set has a defective SMALL SIGNAL BOARD.
Toprol
Jul 31, 2007 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
