We was using tp link5210g for last two years. But now suddenly it leaves the working completely. We have upgraded it but still problems remain. It will work just 5 minutes after on and some time it wi
TP.WA5210G
  • 3,320 Answers
Use some compressed air to blow out all the dust. As computer components age they become much more sensitive to over heating. Make sure there is adequate ventilation around the router.
Posted on Mar 28, 2014
4 Suggested Answers
  • 167 Answers
SOURCE: hi, i had installed TL-WA5210G (TP
try to face the antenna to a different direction until you got a good signal first.
Posted on May 23, 2011
SOURCE: i recently purchase a TP
Are you using straight cable or cross cable. you must use straight cable for configuring this router. If LAN light does not turn on after using straight cable then there must be problem with router itself.
Posted on Jun 07, 2011
  • 22 Answers
SOURCE: in my device wirless strangth
http://www.tp-link.com/en/support/downloadFiles.aspx?mid=01030301&version=V1&pmodel=TL-WA5210G
Seems a problem with the firmware. Double check if your product is the same as the link above and apply the fix described in the support page.
Top firmware version 09/30/2010. this firmware version will include the previous fixes like LED is not ON. Download the file decompress and execute. Please use a wired connection (CAT5/6 network cable) between your computer and the outdoor device. Do not use the wireless connection and be sure that both devices (source computer and destination AP/router/wireless TP device are powered up at mains (no batteries). Back-up yor settings as a firmware update is possible to erase all your settings.
A bit of trivia:
Your wireless outdoor device is decent but not "50km". For that you need a big comms tower.
Good luck.
Posted on Jun 29, 2011
2013 triumph rocketiii touring bike. I have occasional problem with engine cutting out when the clutch is pulled in and and im coasting to a stop tp sensor was replaced last year.
You could try the 12 minute tune.This is in the workshop manual.
start the engine from cold,do not touch the throttle at any time,leave running until the cooling fan starts and then leave engine running for 12 minutes and then turn off and restart.This process resets the computer parameters.Engine must be cold to start with.
Aug 22, 2013 | Triumph Motorcycles
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Apr 19, 2012 | TP-LINK TL-WR642G Router
Slow print jobs.
Old age printer & originally it wont supports win7,hp not upgrading the old series due to upgrading involves costing..
Dec 22, 2011 | HP DeskJet Office Equipment & Supplies
Have a GE GG40T6A gas hot water tank. Leaking really bad out of the pressure relief valve. It is a rental property, gas was off to the house (tenants moved out in the night). When the gas company turned...
12 year old water heater is getting near the end.
Some tanks last 20 years, but that's the exception.
To find exact age of your brand water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Leaking TP valve:
1) Lift TP lever and gently lower back into position to see if that stops leak.
Occasionally something gets stuck in the valve.
2) Sometimes water heater temperature gets turned up because heater is not producing as much hot water as before, and higher temps cause TP to release pressure because of overheating.
Dial temperature down to 120 degrees.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) If steps above don't fix problem, replace TP valve >> TP valves have 125 or 150 degrees rating >>> older tank shouldn't be running above 125 because higher temps cause more pressure on tank, so thermostat should be lower than 125 degrees TP rating.
Buy replacement TP at any hardware store + a roll of teflon tape to seal pipe threads.
Turn gas control to pilot ... this will keep pilot lit but burner will not fire.
Let water cool, and then drain some water out of tank.
If TP valve is on side of tank, then open drain on side of tank and drain water until it is lower than valve level. Open bathtub spigot to let air into line.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Be careful around water that is higher than 120 degrees F >> you can get burned quickly >> apply cold water to any burn.
Use pipe wrench and unscrew TP valve counterclock-wise.
Install new TP and put teflon tape on threads.
Re-fill tank completely and open tub valve on hot side until water is running >> then turn gas control back to original position.
Do not fire up any water heater before tank is completely full of water or this could damage tank.
To read more preventative information about water heater leaks and age problems:
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Nov 24, 2010 | General Electric GE SmartWater Household...
Bootup prob with M2N68-AMPLUS with AMD 7750 CPU. It has a
A couple of things that could be causing this.
Have you tried plugging straight into a wall outlet rather than the UPS to see if you have the same problem? If plugging into the wall fixes it, you have a bad UPS.
Next, have you tried replacing the power supply? It could be that your power supply is either failing or underpowered for your PC components, especially if you have upgraded something like your video card.
It could be an overheating problem. Download the SpeedFan application (freeware...search Google for "speedfan") and look at your system temperatures. If they have the little fire icon next to them, check which component is having the problem. Replace or upgrade the fan for that component. If it's ambient case temps, additional intake and/or exhaust fans may help.
Upgrade all of your PC's drivers and firmware (available through Asus' website).
Remove all external, unnecessary devices (leaving just your mouse, keyboard, and monitor).
Last option could be failing components. Since you said you upgraded your RAM and HDD, that leaves power supply, video card, CPU, and motherboard. If possible, swap these out with another PC's parts. If not possible, I would start with power supply, then CPU, then video card, and then motherboard.
Aug 21, 2009 | ASUS Computers & Internet
Display black out / problems
Hi, I am having the same problem. and now my screen is completly blank, did u find any other solutions?
Jun 26, 2009 | HTC S710 Smartphone
Two vertical lines on my compaq presario (M2000)
Try changing your screen desktop resolution to a different value. If you still have verticle lines, then try changing the color depth from 32bit to 24 or 16. If the problem remains your display adapter has completely failed. It has failed to compute column row addressing math.
Naturally, you would want to find and install the latest drivers for your display adapter with the hope that the failure is in the software driving the display adapter and not an onboard chip. If updating your drivers fails to resolve the issue you need to have service performed on your laptop. Most laptops have the display adapter soldered on the main circuit board and many shops are capable of replacing this chip set.
Yet, get a quote first as the cost might cause you to consider an upgrade into a laptop that has a display adapter that is Direct X 9c or Direct X 10 ready as that will run most of the new game titles coming out this year.
Let me know if you have any further need of assistance as you run through the above troubleshooting routine.
I do hope this has fixed ya!
Worldvet
May 16, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
