Hotpoint aqualtis wont stop spinning, says 1 minute left spin stops for minute then re-starts also noticed spin sounds louder and gratey
Door lock stays on
Jimster
  • 240 Answers
SOURCE: hotpoint wma10 washing machine wont stop filling up
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Posted on Sep 07, 2007
SOURCE: My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Posted on Aug 03, 2008
SOURCE: stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Posted on Nov 02, 2008
beltronic205
  • 1474 Answers
SOURCE: The drum wont spin and then the LEDS start flashing
Could be motor brushes....
Posted on Nov 11, 2009
cpldw48
  • 207 Answers
SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
Posted on Apr 25, 2010
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
Nissan Altima 96 doors wont stay locked.
REPLACE YOUR DRIVER SIDE DOOR LOCK MOTOR BEFORE YOU REPLACE IT DISCONECT IT FROM ELECTRICAL CONECTOR TRY LOCKING CAR IF IT WORKS THEN REPLACE THE LOCKING MOTOR LET ME KNOW MABY I CAN HELP IF YOU NEED ME TWO OK
Nov 13, 2012 | 1996 Nissan Altima
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
2004 maxima rear door locks stay locked after i
MOST LIKELY ATHERES A CHILD PROOF SWITCH ON ONE ORBOTH DOORS ON THE PART THAT SHUTS
Jul 20, 2010 | 2005 Nissan Maxima
Central locking not working, doors lock then unlock when just want them to lock
one of the door doorlocks is faulty the door lock link switch thinks the door is open and wont allow it to stay locked it can be plugged into the diagnostic socket and that would tell which one is faulty or the slow way is to disconect each door lock one by one until it stays locked then u will no which one is faulty
Apr 19, 2010 | 2000 Ford Focus
1998 Durango doors don't stay locked.
There's a sensor or switch in the ignition cylinder that is there to keep you from locking the doors using door switches when the key is in the ignition. This is performs just like you are describing. The doors will lock then immediately unlock. Maybe the sensor/switch in your ignition keylock is bad or disconnected somehow.
Best of luck
Feb 04, 2010 | 1998 Dodge Durango
Front Driver's side door won't stay locked
It sounds like your lock actuator is dead....ya need to replace the lock actuator.
Aug 29, 2009 | 2004 Kia Optima
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
1998 Ford Windstar fuse problem - dome light stays on etc
you most likely have a bad door ajar switch- the door panel has to be removed to access it, its on the door latch- you can unplug them this will take care of the batt drain prob.as for the locks it may be a switch problem- most ford vehicles will not let you lock the vehicle from the driver's door when it's open to prevent locking the keys in.
May 26, 2009 | 1998 Ford Windstar
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
